fitting size for autometer fuel pressure guage
Old Feb 18, 2010 | 04:03 PM
missinganova's Avatar
missinganova
Default fitting size for autometer fuel pressure guage
I did a search on this; but couldn't come up with a definite answer.
I picked up an autometer fuel pressue guage on ebay for 20 bucks and built a bracket to mount it above the windshield and underneath the hood.
Does anybody know what the fitting size is on the test fitting on the fuel rail?
I would assume you could take the cap and schrader valve off and run a stainless line from the top of the fitting in the rail.
Old Feb 18, 2010 | 10:34 PM
rodj's Avatar
rodj
Originally Posted by missinganova
Does anybody know what the fitting size is on the test fitting on the fuel rail?.
-4 AN
You don't say what engine you have but if you have a TPI you use one of these to clear the plenum and get the 1/8"NPT gauge port Installs without taking the intake apart. Cap the open end.
http://www.summitracing.com/parts/RUS-670290/
LT1 could probably go straight on with a -4 AN fitting
Old Feb 22, 2010 | 05:00 PM
missinganova
TPI
Thanks for the info...
Old Mar 10, 2010 | 03:57 PM
vstol's Avatar
vstol
LT-4; Electric Auto Meter Fuel Pressure Guage. Need female to the rail and male to the auto meter sending unit which I believe is 1/8 NPT . Thanks
Old Mar 10, 2010 | 04:36 PM
rodj's Avatar
rodj
Still need the -4AN adapter I listed to mount to the TPI fuel rail
Old Mar 10, 2010 | 05:59 PM
vstol's Avatar
vstol
Thanks but I screw'd up I was looking for a connector with female ends on both sides, is there such an animal that would work
Old Mar 10, 2010 | 06:13 PM
rodj's Avatar
rodj
Though you were posting a reply to the OP's question , not asking a question of your own
You want to fit a 1/8" NPT sender unit on to the LT rail?
The adapter I posted in the link above will do that ;effectively a -4AN female to 1/8"NPT female adapter
Old Mar 13, 2010 | 09:02 AM
vstol's Avatar
vstol
http://www.metcomotorsports.com/prod...p?prod=MFF0001
I spoke with Auto Meter and this is the adaptor they use and the one I am going with.
Old Mar 13, 2010 | 09:31 AM
floridamale's Avatar
floridamale
I used a 45 elbow so the gauge would sit at the right angle to read it.
Old Nov 16, 2011 | 09:20 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Great pic! Nice, clean and neat engine bay!
To fitting size for autometer fuel pressure guage
