Rear end drain plug
Old Feb 20, 2010 | 11:50 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Rear end drain plug
went to change my rearend grease and noticed the drain plug is not all the way in but it is tight, took it off cleaned the threads and still only goes in a little more than half the way. Is this normal?
Old Feb 20, 2010 | 12:19 PM
Aardwolf's Avatar
Aardwolf
Yes.
Old Feb 20, 2010 | 12:35 PM
kimmer's Avatar
kimmer
Thankyou .
Old Feb 20, 2010 | 01:28 PM
383vett's Avatar
383vett
Next time you are under there, remove the plug again, suck out the old fluid and replace with fresh fluid.
Old Feb 20, 2010 | 05:08 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Old Feb 20, 2010 | 06:33 PM
ex-x-fire's Avatar
ex-x-fire
Are you talking about the fill plug? A drain plug is at the bottom if one was added to the housing.
Old Feb 20, 2010 | 06:39 PM
c4cruiser's Avatar
c4cruiser
C4 diffs never had a separate drain plug. Gear oil has to be sucked out through the fill plug hole.
The accessory catalogs used to have a drain plug kit that required drilling a hole in the bottom of the carrier but you had to be real careful where you drilled. If you weren't nearly perfect in measuring, you could hit the ring gear or not be able to get the plug inserted far enough to seal properly.
$3.50 plastic fluid pump from Harbor Freight works to suck old fluid out and pump new stuff in.
To Rear end drain plug
