CAGS bypass
Old Feb 20, 2010 | 11:55 AM
GRNVNM93's Avatar
GRNVNM93
Default CAGS bypass
The instructions that came with my CAGS bypass say to disconnect the negative cable to the battery. Is this a must?
Old Feb 20, 2010 | 12:07 PM
c4cruiser's Avatar
c4cruiser
Shouldn't be. But you should not have the key in the ignition when installing the plug. Actually, you don't even need the bypass to kill CAGS. Just pulling the wire from the tranny and covering the connector with electrical tape does basically the same thing. The upshift light just stays on.
If you look thru the FSM or just about any repair manual it says to disconnect the battery before doing most any work. At our shop, the techs usually don't disconnect the battery unless it's an engine removal.
