Well I spent the day out in the garage with my drill press, die grinder, and my valves. I've ported the heads already, so the next step was to reshape the valves a little bit. I thought I'd make a video too so here we go:
very nice will we have before and after flow charts?either way,im glad to see that you aint skeerd to do something like that.will you have to get the valve and seat re-ground?
I did somewhat of the same thing when I rebuilt my heads. I noticed the sharp ridge on both int and exh valves. I also went into the bowl area, particularly the transition from the bowl to the seat. I couldn't believe the mismatch.
I didn't flow the heads afterwards but felt that it was time well spent.
It's simply removing material from the path of flow.
I don't have access to a flow bench, but it would have been nice to put a number on what I've done with the heads. No need to touch the seats, I didn't get near them.
Originally Posted by HiTech5
I did somewhat of the same thing when I rebuilt my heads. I noticed to sharp ridge on bot int and exh. I also went into the bowl are particularly the transition from the bowl to the seat. I couldn't believe the mismatch.
Thanks for the vid.
I agree, as long as a fella's got his heads apart, might as well do everything he can to improve them. Glad you liked the video
It would be interesting to take one untouched valve and one you took your grinder to, stick them both in the same port and have them flowed for curiosities sake.
On grinding on those though....who told you to do that?
Great, just when I told myself I was going to leave my heads alone. Well, time to buddy up with my neighbor and see if he'll let me use his drill press...................
Not to rock the boat guys but imo leave this stuff alone, cant just blindly take grinders to parts expecting to make a power breakthrough;,ore than likely the part will get ruined, not work right or worse yet fail on you.
Kangi sure you know to get the valve job redone before dropping those in. have them inspected to make sure they didht get weakened in the process. not criticising as it seems youre having fun modding your stock stuff, just sayin to know where the line is and all .
