Need help with an 89 TPI
I took a peak at it, saw the ect was seeping coolent and since a faulty ect can cause a rich condition I threw one at it, symptoms didn't change.
My second guess was an o2, had one left over from my car and threw it in, running condition improved slightly. Also before I threw parts at it I hooked it up to a tech l, the tech l would never get a continuous stream of information so it was worthless. I then purchased a usb/aldl cable (http://www.aldlcable.com/) to use with my laptop and it wouldn't connect. I don't know if it's because of the car or because of a fault on my end, I haven't tried it in my car yet.
And before I put any parts in it I pulled the ecm and prom to see if I could find any corrosion or anything else that would obvious, found nothing.
Only other sensor on it that controls a/f ratio is the maf and tps that seem to work perfect using a fluke meter.
So I'm at a loss, any ideas?
-jumper ALDL pins 1&2 (upper right)
-turn the keys On and record the SES flashes
-when you see the 2nd set of "12"s, turn off the ingition and remove jumper
To test for closed loop mode:
-start the engine and watch SES flash rate
-initially it will be 2Hz,
-after a minute or two it should drop to 1Hz, indicating closed loop mode
The ect sensor that was replaced was the one for the ecm, at the base of the intake on the front of engine.
Since the O2 is only one side, failure of 1 or 2 injectors on that side can cause the ECM to compensate for what it thinks is lean. And, you get rich.
Measure resistance of injectors hot and cold. Should stay about the same (@ 15-16ohms).
I had 2 bad, car never thew a code. Ran like crap.
