Tuning a '90 L98 engine
Old Feb 25, 2010 | 07:19 AM
corvette95's Avatar
corvette95
There is a lot of good ideas and guessing here. Any and all could be correct. If you took the car to a dealer, they can pinpoint the problem if the tech was knowledgable and cared. For one, he can take the injectors out, they should have a injector driver tool (Kent Moore) and they can do a flow and pattern test of each injector in a glass jar and see how well and how much each injector sprays. Not a big job other than removing the plenum. I just hate to people spend money guessing at problem when there are ways to test them first. And BTW replacing the injectors will PROBABLY be the problem, but its nice to know first. Could also be in ingition system from plugs to distributor, also wont throw a code. Good Luck!
BTW IF and ONLY IF you decide you replace your bad stock injectors, I would like to have them to rebuild them for an NCRS project for a reasonable $
Old Feb 25, 2010 | 05:33 PM
jimmers's Avatar
jimmers
Originally Posted by 65Z01
Wow, $350 for a heater core ain't too shabby...
I'm hopeing thats with labour!
Old Feb 25, 2010 | 11:16 PM
91GreatWhiteShark's Avatar
91GreatWhiteShark
All excellent advice so far. I would also take a look at the IAC valve (Idle Air Control Valve). The pintle builds lots of carbon on it and can fall out of adjustment. You'll have to remove the throttle body to access it and remove it. Get some throttle body cleaner and spray it on the pintle liberally. Take a soft brush and work the carbon loose and spray again. Then adjust the pintle to the factory specs. Sorry it's been a while since I did this to my 91, but you can find the spec in a manual. I actually purchased a new one and installed it. It made a difference on how the car idled.
Old Feb 26, 2010 | 07:29 AM
ksch994462's Avatar
ksch994462
Thanks for the info and advice. I spoke with the service rep yesterday and they hadn't yet completed the diagnosis. He said it could be the PCM, which was determined to be the culprit on another c4 they worked on. I should find out today. It's all still in limbo. Tks again....
