84 vette Cross fire Nitrous
Old Feb 25, 2010 | 10:24 PM
Mr.1984's Avatar
Mr.1984
Default 84 vette Cross fire Nitrous
Need help with a crossfire injection nitrous set up!
just need a list of parts to buy. My goal is not to go entirely big just a 75 hp wet shot. here is what i got so far
edelbrock 10lb bottle
temparary engagement switch
3 toggleswitch panel
Old Feb 26, 2010 | 08:31 AM
jsiddall's Avatar
jsiddall
I found it is usually cheaper to find a kit that has most of what you are looking for then add bits as necessary. Not sure exactly what kits work on a crossfire, but a quick google should get some hits. You should be able to find some kits without bottles if you don't need/want to have two.
Old Feb 26, 2010 | 12:00 PM
snoopdan's Avatar
snoopdan
you'd have to use some seriously small jets on that, and it looks pretty easy to build.
Old Feb 27, 2010 | 09:24 PM
Mr.1984's Avatar
Mr.1984
how does 50 hp jet sound?
Old Apr 20, 2010 | 11:09 PM
alterchristopher's Avatar
alterchristopher
engine should be good for a 100 shot if its in good condition here are some pics of an nos kit
i was going to us brake lines for my kit
Old May 10, 2010 | 05:36 PM
84compuvette's Avatar
84compuvette
That's the setup that I'm going to re-create on my engine as well. Got all the parts to do it, just lack the guts to bolt it on........
Old May 13, 2010 | 01:30 AM
mcm95403's Avatar
mcm95403
Why?
It's not like you're bolting on a 400hp plate system or something. Just keep the jets small, and if you have any questiosn, talk to NOS, Edelbrock, or whoever you're using the most parts from. They'll help you to make sure everything is set up correctly.
Like any major mod, be careful and watch things closely till you get used to it and know it works correctly.
Marc
Old May 14, 2010 | 06:44 AM
84compuvette
Originally Posted by mcm95403
Why?
Marc
I'm just a whimp and don't want to grenade the engine. I've got jets for 70hp and 100hp so it'll be tame. I just want to get my EBL computer setup first as I'm just running a stock ECM with an ADL "off-road" chip in it now. I'm sure my tune is pretty far off.
Old Oct 12, 2010 | 11:06 PM
mcm95403's Avatar
mcm95403
Curious if you got this setup going yet............
Old Oct 12, 2010 | 11:19 PM
Mr.1984's Avatar
Mr.1984
My setup was stolen over the summer. I had everything needed to do the nitrous. but now i am kind of glad they did because my engine is slowly starting to wear away. i guess it just wasnt meant to be. but this winter im going to rebuild it and maybe have a base hp of 450 so i will not need nitrous. also changing the intake to projection FI.
Old Oct 13, 2010 | 09:57 AM
mcm95403's Avatar
mcm95403
Well, that sucks. I'm interested in what you have planned for the new engine though. Have you seen the Renegade intake yet?
Old Oct 15, 2010 | 07:05 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Did you get your car running with the renegade yet? Have you did the post dyno run yet?
Old Oct 16, 2010 | 09:05 AM
mcm95403's Avatar
mcm95403
I had a problem and had to leave it parked last weekend. I'm headed up there now to see if I can sort it out. The Renegade was fine, the problem was with the valve lash - possibly that the cam is going flat.
Old Oct 16, 2010 | 02:37 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
That production kit is no longer available for CFI, but you may still be able to buy the parts or cobble something together and make it work. If I remember right, there was a guy that was featured in one of the vette mags a number of years ago that ran the CFI kit in his 84 and ran like 11.4s or somethng like that with it. I just don't remember all the details anymore, but you may be able to Google it. Good luck and don't let it go lean.
Old Oct 17, 2010 | 10:40 AM
mcm95403's Avatar
mcm95403
It's here:
http://www.gmhightechperformance.com...tte/index.html
Old Oct 18, 2010 | 01:07 AM
Buccaneer's Avatar
Buccaneer
There you go, thats the one. Nice read.
To 84 vette Cross fire Nitrous
