93 Computer Chip Removal
Old Mar 9, 2002 | 08:44 AM
webmstrjay's Avatar
webmstrjay
Default 93 Computer Chip Removal
Based on the forum recommendations, I'm going with a FASTCHIP and lower thermostat to keep the Corvette cooler in the heavy traffic. I have contacted Ed and am ready to go. He needs the letters off the chip. I understand the chip is under the passenger dash, but exactly where I don't know.
Could anyone tell me where it is (and any removal hints) so I can call Ed?
I have only upgraded older/lower technology cars (65 vette, 70 chevelle), I would be out of the water without this forum!
Thanks to everyone!
Old Mar 9, 2002 | 09:23 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 93 Computer Chip Removal (webmstrjay)
Have you tried asking in the ECM/PCM section?
Old Mar 9, 2002 | 09:59 AM
92corvette's Avatar
92corvette
On my 92, the computer is under the hood, black box right above the battery. THe 93 might be aluminum instead of black. And my 4 letter code was on the 'outside' of the box. I didn't have to remove it to get the code, it was right on top. BTW, my code was 'AZUM'. Ed's chip will have instructions on how to install it.
Old Mar 9, 2002 | 10:45 AM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
Default Re: 93 Computer Chip Removal (92corvette)
The box is located as indicated above. Disconnect the negative battery terminal. Remove the three nuts that hold the box in the frame. Do not disconnect any wires or plugs. Turn the box over and you will find an access cover with 4 screws holding it into place. Remove the cover and you will see the chip. It is similar to a SIMM chip in your computer, but much fatter. The original color might be light blue. There are 2 clips, one on each end. Push down on the clips and the chip will lift out of the socket.
The new chip you get might resemble the one you took out exactly. Others are configured in a piggy-back fashion. My chip is a Performance Resource chip and it looks exactly like the factory original. I am more than satisfied with my chip. It meets all of my expectations.
:seeya Purp
Old Mar 9, 2002 | 11:14 AM
FSTRNU's Avatar
FSTRNU
Default Re: 93 Computer Chip Removal (PurpleC4)
Hey Purp where did you get your chip from??? What all does it have on it?
Old Mar 9, 2002 | 12:18 PM
92LT1Roadster's Avatar
92LT1Roadster
My 92 is under the hood as well. EASY! YOu'll see. THe fastchip will Piggy Back on you chip/..... Instruction are included. 15 minute job!
PS. I have had Jet stage II and Hypertech stage ll. The Fastchip is FAR SUPERIOR and I just love it!!!!!
[Modified by 92LT1Roadster, 10:20 AM 3/9/2002]
To 93 Computer Chip Removal
