Automatic Shifter Knob
Old Feb 26, 2010 | 06:45 PM
jmcquade's Avatar
jmcquade
Default Automatic Shifter ****
I need to replace my Shifter Lense , but can figure out how to get the automatic shifter **** off . 87' Automatic
Old Feb 26, 2010 | 07:37 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Pry out the button
Remove the C-clip at the inside base of the ****
Lift the **** off the shifter rod
Old Feb 26, 2010 | 07:39 PM
WW7's Avatar
WW7
Originally Posted by 65Z01
Pry out the button
The only thing I can add is it makes it easier if you have a set of split ring pliers..WW
Old Feb 27, 2010 | 01:44 PM
jmcquade's Avatar
jmcquade
Worked Perfectly- Thanks
Old Feb 27, 2010 | 09:48 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Just a suggestion. Buy the FSM manuels if you dont already have them.
They give you step by step instructions for something even as menial as this. I learned that when I changed my leather boot that had split.
They are invaluable.
Laura
To Automatic Shifter Knob
