Chassis Lube Advise
Old Mar 9, 2002 | 01:09 PM
TomsZ06's Avatar
TomsZ06
Default Chassis Lube Advise
This morning I lubed my fron upper and lower ball joints along with the steering joints. In my repair manual it says to lubricate the rear anti-sway bar which the manual stated is unique to the Corvette. I was not able to find any fittings or plugs that would accept a fitting. I have a 92 LT1 6-speed.
Old Mar 9, 2002 | 02:07 PM
ittlfly's Avatar
ittlfly
Default Re: Chassis Lube Advise (TomsLT1)
I've got a '92 also and have been lubing my car for the last 10 yrs ....I have read the same thing in the shop manual but there are no fittings that I have ever found. So I use a silicon spray on the sway bar bushings (and all other rubber bushings too.)...Car has always been very quite and I have not had to replace any of the bushings, anywhere....knock on wood... :D
