Wheel Hubs
Old Feb 28, 2010 | 02:29 PM
Marv02's Avatar
Marv02
Default Wheel Hubs
I starting to look for some aftermarket wheels for my 1986 Vett I founding out once again I don't have very much to choice from unless I use wheel Adapters I not to hip on that Idea.
Can I change out the Front hub Bearing and the rear axle units to a 1988 on up so I can more wheels to choice from.
Or would you use wheel Adapters ?????????????? if I went this way how bad will this screw up the cars handling do to different wheel offset.
And what size tires should I use with 17 or 18 inch tall wheels and how wide of a rim should I use.
Old Feb 28, 2010 | 03:25 PM
catmech's Avatar
catmech
im interested in the answer to this question as well
Old Feb 28, 2010 | 07:41 PM
rodj's Avatar
rodj
Originally Posted by Marv02
Can I change out the Front hub Bearing and the rear axle units to a 1988 on up so I can more wheels to choice from..
The difference is in the suspension ; not the hubs
Rear hubs are same '84- 96.Front hubs have differences relating to ABS sensors but are same dimensions.
The adapters returns the late wheel to the correct position on a early car
Old Feb 28, 2010 | 08:20 PM
Marv02's Avatar
Marv02
Thanks Now we know.
So wheel adapters could be a good thing to do after all.
Old Feb 28, 2010 | 08:26 PM
COPO's Avatar
COPO
Thanks Now we know.
What wheel are you looking at & what offset or back spacing.
Old Feb 28, 2010 | 08:52 PM
Marv02's Avatar
Marv02
Just looking now if I go that route just getting alll my ducks in a row before I find out I should researched it some more before I spent all that cash just to find out there was a better way only if I looked into it more.
Old Feb 28, 2010 | 09:00 PM
rodj's Avatar
rodj
Your car has 32 or 38mm offset ( dependent apon 8.5" or 9.5" rims )
You can buy aftermarket wheels with correct offset so you don't need spacers
Exp
http://www.marketworks.com/storefron...2068&i=9719410
Anything off a later model Vette (56mm offset ) will require the adapters
Old Feb 28, 2010 | 10:12 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I have a set of wheels that will work on your car with only a 1/4" spacer. They may fit without anything but Im not 100% sure since I dont have an early model.
http://forums.corvetteforum.com/c4-p...post1573235410
To Wheel Hubs
