a4 shifter question
Old Mar 1, 2010 | 04:46 AM
Mohammed_z's Avatar
Mohammed_z
Default a4 shifter question
Why my shifter starts with 2 ? not 1
most I see are like this : 1 2 d D N R P
while my shifter is like this : 2 d D N R P
I'm not getting this
Old Mar 1, 2010 | 09:53 AM
surfer92's Avatar
surfer92
What year?
Old Mar 1, 2010 | 01:16 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Are you saying that the shifter won't go into "1" or that there is no "1" on the indicator plate??
Old Mar 1, 2010 | 06:16 PM
markKlein's Avatar
markKlein
please post a clear, close up picture
Old Mar 1, 2010 | 06:52 PM
dogfish246's Avatar
dogfish246
No one will be able to help unless we can see better...
Old Mar 1, 2010 | 07:18 PM
pologreen1's Avatar
pologreen1
get pics
Old Mar 1, 2010 | 10:05 PM
Mohammed_z's Avatar
Mohammed_z
right , there is no ''1'' on the indicator
it's 1994
Old Mar 1, 2010 | 10:20 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
Looks like someone removed the console and did not position the gear indicator back in the right place during reinstallation.
When in park, is the idicator directly over the "P"?
Old Mar 1, 2010 | 10:24 PM
Mohammed_z's Avatar
Mohammed_z
Yes it's in P when park
Old Mar 1, 2010 | 10:25 PM
Mohammed_z's Avatar
Mohammed_z
this is the right description guys
Old Mar 2, 2010 | 06:14 AM
Joe C's Avatar
Joe C
it's 1994
i'm pretty sure i understand what you're saying. the only pic i've found of a 94 console assembly shifter shows a number "1" on the lens, so i'm assuming they left the factory that way. the same applys to the 91-93 configurations.
my question is, can you manually shift into first? does your shift indicator point to where the number "1" should be?
if you can shift into first, and the needle points to where "1" should be, it seems there are several possibilities - either someone removed the console and "erased" the number, you have some sort of factory flaw, and the number was never imprinted on the lens, or if you have an export model, its some sort of export feature. the latter might be true if you physically cant put the shifter into the "1" position (even though in drive, the transmission starts out in low). i'm by no means an expert on the export model, but my best guess is it might be some sort of export feature. ???????????????
Old Mar 2, 2010 | 07:57 AM
Mohammed_z's Avatar
Mohammed_z
I've called a tuner , and he said like what u said , it's an export specs . and this can be changed by modifiying the shifter itself . I may take the car to him this weekend . it's one hour job.
thanks all and sorry for not making this clear
To a4 shifter question
