Any C4's with a 502? :D
Old Mar 2, 2010 | 12:27 AM
94lt1vette94's Avatar
94lt1vette94
Default Any C4's with a 502? :D
Hey guys,
I've actually debated doing this , obviously it's not the most cost effective route
Anways, has anyone ever dropped a 502 in a C4?
Here's the one I've been glancing at:
http://www.crateenginedepot.com/stor...121-P8C54.aspx
Old Mar 2, 2010 | 12:42 AM
pologreen1's Avatar
pologreen1
If it is for fun or say I have a 502, but For that amount of money alone on a motor, not including all fab work and parts, you could easily build a 396 or get a 400+ plus motor that will make more power, and bolt right in. In fact I'd bet you could have money left over to upgrade drive train, considering there is a 421 600+ hp motor here brand new for like $4500 needs assembly.
Just my opinion. Yes you could build the 502 to even more extreme, but then imagine the investment.
Old Mar 2, 2010 | 04:17 AM
mnstrlt1's Avatar
mnstrlt1
The big block idea get's tossed around a few times (it seems) a year. I actually posted a thread about this a few months back. doesn't seem to generate any interest among the forum members (i.e. doesn't end up being a thurough, informative thread).
However, the big-block swap "does" require some fabrication, but it doesn't really sound "as bad" as some make it out to be. Of course, I don't have any first hand experience. But the good news is that the bell-housing bolt pattern is the same as a small block, so you can essentially slap the big-block to your existing 6-speed or automatic.
I've been told that depending on the belt drive components that you retain (use) and the crank pulley that you select may require notching the front cross member for clearance. I do believe that the engine mounts are also interchangeable between the two blocks.
The few forum members that have a big-block c4, and the few articles surrounding this topic do mention that the frame does see an increase in flex due to the power increase. So I'd opt for a 4-point or 6-point bar into the build.
If you plan to keep the creature comforts (i.e. A/C) than you need to do some research to see what factory (or aftermarket) brackets can be used.
my dream big-block build would consist of an alloy-block, 600+ cubic inches! At that point, you can toss the idea of "equivalent to a small block" out the window.
Of course, I had also cross referenced the idea of going with the current LS-x based 500+ cubic inch beast! Of which, the belt driven components, intake manifold (for EFI) and even headers have already been figured out! the best part is that it would look like a small-block Ls-x externally. Ample room to work on the engine, cutting edge GM technology, dozens of parts suppliers. etc.
*edit*
BTW- if you browse the c5/c6 forums, you'll find that guys are making more than 600rwhp (no power adders) with "only" 400-430 cubic inch Ls-x engines! That's without breaking the bank (sort to speak).
400 cubic inch short blocks are seriously affordable these days too (if you go with a power adder). the supercharged c5/c6 guys are seeing 600-700-800rwhp with the correct supercharger, pump gas, and meth inject.
Old Mar 2, 2010 | 07:48 AM
rodj's Avatar
rodj
http://vettextc.jiminees.com/jeff/C4_BBC/C4_BBC.pdf
http://www.3cinc.net/Motor.html
The how to instructions
http://www.digitalcorvettes.com/foru...ead.php?t=1756
Old Mar 2, 2010 | 09:13 AM
94lt1vette94
Woah that looks awesome. I've always dreamed of dropping a 502 into something...
http://www.youtube.com/watch?v=iBBiN4RRRyQ
Old Mar 2, 2010 | 09:18 AM
chevyforever's Avatar
chevyforever
The owner of "Movit - The Brakes" Guido Frensemeyer even installed a 572 cui in his C4 ZR-1.
http://www.movit.de/htm/corvc4572.htm
Dyno run: http://www.movit.de/images/572leistungsmessung.wmv
317 km/h at the Autobahn: http://www.movit.de/video/zr1video.wmv
And yes, we in Germany are nuts, too!
Regards
Rico
Old Mar 2, 2010 | 09:30 AM
94lt1vette94
Woah, that is sick! Question: why would you buy a zr1 is u planned to swap the motor?
Old Mar 2, 2010 | 09:41 AM
cv67's Avatar
cv67
St. Jude Donor '05
502 over any small block
Old Mar 2, 2010 | 01:49 PM
GlennS87's Avatar
GlennS87
RHS has a LSX block that could end up 502 cu. in. It might be less fabrication using that although I'd guess the build would still be sick expensive. From a weight/balance perspective you would be better off.
Old Mar 2, 2010 | 02:15 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
1) for show
2) a BB only weighs a pound more
Old Mar 2, 2010 | 02:24 PM
96z51's Avatar
96z51
as cool as a BB would be why not build a supercharged sb. seems like the easiest way to make big power without it being a huge PITA.
Old Mar 2, 2010 | 08:14 PM
94lt1vette94
OR, why not build a supercharged BB?
Old Mar 2, 2010 | 10:01 PM
timbradley26's Avatar
timbradley26
why not just call scott schafroff and have him send you one of his 472 in small blocks 10k gets you the motor and no fab work. he even uses a dart block . you could tell your buddies its a 350 leave a stk cam in it and have the ultimate sleeper . hmmmmm may have to look for a 90 c4
Old Mar 2, 2010 | 10:55 PM
miker2's Avatar
miker2
i remember john lingenfelter telling us about a big block install he did for a customer from chicago. i think the guy was street racing.
Old Mar 2, 2010 | 11:36 PM
mnstrlt1's Avatar
mnstrlt1
I want to hear the details of that conversation!
mnstrlt1's Avatar
mnstrlt1
Already did the small-block and blower- now I want a BB with turbo/s!
Old Mar 2, 2010 | 11:40 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
My Reher & Morrison 412ci small block dyno'd 687hp at the flywheel...
To Any C4's with a 502? :D
Old Mar 3, 2010 | 12:00 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
I saw a C4 with a 502/502 in San Diego's car Dreamin Car Show last year. I had pictures but deleted them.
The 502 engine is WIDE, so wide that the manifold was rubbing against the upper control arm on the passenger side. The owner told me it ran very strong. Like all engine swap projects without the proper wiring, looked excessively "juried-rigged".
Old Mar 3, 2010 | 07:38 AM
pologreen1's Avatar
pologreen1
Thats why I say it is not worth the cost of a BB motor for only 500+ hp.
Old Mar 3, 2010 | 11:23 AM
esham's Avatar
esham
My Dad bought a 1990 Big Block last year. My avatar shows a picture of the engine. According to the documentation, the car was taken to Lingenfelter in 1992 for the swap. It has a forged 540 ci BB Bowtie GM engine with the ZF6 transmission with AC. It came with a dyno sheet showing about 640 flywheel HP. No emissions. I have driven the car a handful of times, and I can tell you that I have never driven anything as fast or as fun. He also has a 1990 TT Aerobody Callaway and I would rather drive the Lingenfelter any day. The Lingenfelter drinks the fuel though. It does not appear to have any extra bracing or frame modification. The serpentine belt system seems to be a one off hand built job. The crank pulley is so close to the frame cross member that in order to change the serpentine belt you have to loosen and move the power steering rack to replace it. Everything fits under the stock hood with a one off multiport sheet metal fuel injection intake manifold that must run off the stock computer system using a different tune. The evaporator box has a modified cover like the ZR1 to obtain more clearance for the engine and headers. I have a stock 90 vert and would love to do a similiar type swap someday. According to Lingenfelter only 4-5 of these swaps were done through them and I would love to know who the owners of the other 3-4 are so I could contact them.
