1.6 Roller Rocker install?
Old Mar 2, 2010 | 07:12 PM
Impala Balko's Avatar
Impala Balko
Default 1.6 Roller Rocker install?
I have a basically stock 94 LT1 6-speed coupe with 100K miles on it and I am looking to do some 1.6 roller tipped rockers. My question is do I have to replace the valve springs when I install these or can I just get away with doing just roller rockers
Old Mar 2, 2010 | 07:23 PM
tblt44's Avatar
tblt44
Old Mar 2, 2010 | 11:01 PM
John A. Marker's Avatar
John A. Marker
With a 100,000 on the engine I would replace the springs while you have it down. You should be able to do both in a weekend.
Old Mar 2, 2010 | 11:42 PM
dogfish246's Avatar
dogfish246
From my extensive research (really extensive) you must replace the springs to at least LT4 spec or better when going with 1.6 RRs
Old Mar 3, 2010 | 12:07 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
If you never plan to rev beyond 4500, keep the old springs.
Old Mar 3, 2010 | 07:36 AM
pologreen1's Avatar
pologreen1
Old Mar 3, 2010 | 07:48 AM
Impala Balko
How do I replace the springs short of taking the heads off. There must be a way to do them without taking the heads off
Old Mar 3, 2010 | 08:24 AM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
There are even some pictures if you search.
IIRC there are two schools of thought:
Use air to keep the valve up
Use rope to keep the valve up
But with 100K on them, and with the minimal amount of work to pull the heads I would reccomend a valve job with new seals and springs.
That way you know the valves will seal right, the pesky valve stem seals won't leak and you will have fresh springs.
To 1.6 Roller Rocker install?
