Help Turbo camshafts ??
Old Mar 3, 2010 | 08:21 AM
red L98's Avatar
red L98
Default Help Turbo camshafts ??
sup guys,
who do u guys think is the best @ picking a cam for my turbo setup ? the motor is a 434 sbc with a Pt 91.5 mm turbo .. Thanks
Old Mar 10, 2010 | 08:30 PM
Bowtie8's Avatar
Bowtie8
Originally Posted by red L98
sup guys,
Mike Moran
http://moranmotorsports.com/
He is in your back yard
nothing better
JW
Old Mar 11, 2010 | 10:51 PM
red L98's Avatar
red L98
Originally Posted by Bowtie8
Mike Moran
nothing better
JW
Maron is the man ,
Old Mar 13, 2010 | 09:47 PM
Orr89rocz's Avatar
Orr89rocz
Need alot more info than just cubes and turbo size... need to know heads/compression/intake setup, turbo hotside setup, goals for power/rpm, transmission/gearing etc etc.
Custom grind is gonna be needed. SOlid roller or hydraulic roller? probably something with a single pattern on a 112 lsa would work well for most.
I have a 401" sbc with twin 60mm units and I have a 233/233 112 lsa .564" lift all around Mike JOnes custom hydraulic roller. Makes decent power and rpm, perfect for my street car. Runs high 9's at 140+
EDIT: seen your other thread. Nasty combo you have. Probably want a solid roller with 260 or so deg duration at .050. I'll leave that up to cam grinders, i dont know what a 18 deg head would want in a blow thru carb setup
To Help Turbo camshafts ??
