Noise coming from the rear..
Old Mar 3, 2010 | 06:30 PM
Goldenboyws6's Avatar
Goldenboyws6
Default Noise coming from the rear..
Ok. 96 Lt4. I started to notice a noise coming from the pass rear tire. I checked everything and did not see anything wrong. It sounds as if the tire or the wheel was hitting the car when moving. I have a feeling that it could be a bad wheel bearing but I am not sure. The noise can be noticed at low speeds or when slowing down (around 15-20 mph). Could someone help me with this? What are the signs of a bad wheel bearing? and how hard and expensive would be to fix the problem? Thanks a lot.
Old Mar 3, 2010 | 07:51 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Jack up the car so that rear tire is off the ground.
Put your hands at 12 and 6 o'clock on the tire.
Push at 12 and pull at 6 at the same time. How far did the wheel move?
Now pull at 12 and push at 6 at the same time. How far did the wheel move?
If you drive on the street a little play is OK, AutoX, road or drag race - replace with even a little play.
No play turn the tire with your hand (yea it wont move much) if you hear clicking its probably U joints.
If play when you jiggle at 3 & 9 its probably tie rod ends.
Old Mar 3, 2010 | 08:38 PM
ch@0s's Avatar
ch@0s
Good info
Old Mar 3, 2010 | 10:20 PM
383vett's Avatar
383vett
Did you check the lugnuts?
Old Mar 3, 2010 | 10:23 PM
jhammons01's Avatar
jhammons01
Or climb under there and check the half shaft u-joints
To Noise coming from the rear..
