Brake caliper upgrade and interfearance.
Old Mar 3, 2010 | 09:03 PM
fastac4's Avatar
fastac4
Cruising
Default Brake caliper upgrade and interfearance.
Will C5 brakes caliper work with 15x3.5 prostar front runners? If not what brake calipers or upgrade can be used that will clear or can be made to clear on a c4.
Old Mar 3, 2010 | 09:16 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
If you're running that small of a tire/wheel setup, why are you bothering to complicate life by transplanting later calipers?
Old Mar 3, 2010 | 09:23 PM
rodj's Avatar
rodj
J55's clear with a 3/16" or 1/4" spacer
Old Mar 3, 2010 | 09:44 PM
Marv02's Avatar
Marv02
I getting ready to replace all my calipers and rotors I understand you can upgrade the front cailpers to C-5 what are J55 I like to use the stock 16 inch rims that can stock on the car.
Old Mar 4, 2010 | 12:47 AM
rodj's Avatar
rodj
Originally Posted by Marv02
what are J55 .
J55 are the big 13" rotor / HD caliper option
Will only fit factory 16" rims made by Enkei
http://www.wheelskin.com/grand-sport-calipers.html
Old Mar 4, 2010 | 10:24 PM
fastac4's Avatar
fastac4
Cruising
Thanks rodj thats what i needed to know that the j55 caliper will clear and is just as good as the c5 stuff.will i need special mounting brackets to install the j55 calipers?
Old Mar 4, 2010 | 10:40 PM
VetteVet86's Avatar
VetteVet86
Default Caliper adapter brackets
I've got a set of the caliper adapter brackets to install J55/Grand Sport calipers on early (84-87) C4's. PM me if interested. They are brand new and were made by "he who lives in Washington state and whose name shall not be mentioned on this forum."
Jep
Old Mar 4, 2010 | 10:50 PM
VetteVet86's Avatar
VetteVet86
fastac4,
You would also need a set of J55 rotors to make this work as well as abutment brackets.
To summarize, you would need:
2 - J55 or Grand Sport calipers
2 - J55 rotors
2 - abutment brackets
2 - caliper adapter brackets
2 - wheel spacers (just going by what rodj stated, as I'm not 100% certain. I was going J55 w/17" wheels before I decided to go w/C5 Z06 calipers. Price for C5 setup was a good bit cheaper than going Grand Sport or J55 route.)
Old Mar 4, 2010 | 11:22 PM
rodj's Avatar
rodj
Originally Posted by VetteVet86
2 - wheel spacers .
Only needed for caliper clearance on the 15" front runners
http://forums.corvetteforum.com/1551511689-post6.html
http://forums.corvetteforum.com/c4-t...ld-wheels.html
To Brake caliper upgrade and interfearance.
