Waterpump noise?
Old Mar 3, 2010 | 09:17 PM
brownc00's Avatar
brownc00
Default Waterpump noise?
I have some noise that seems to be coming from the front of my engine. It kind of sounds like something metal getting chewed up in a blender at low speed. It's not a steady or consistent noise, but it is fairly loud. Also as the noise occurs, you can see the tensioner bounce up and down a bit. I pulled the belt off the car and spun everything and all was quiet except for the alternator and it wasn't that loud. It just made more of a whirring noise. I did not start the car with the belt off but I will do that soon.
So, does a dieing waterpump make that type of noise. I was able to move the shaft a tiny little bit when I grabbed the pulley.
Old Mar 3, 2010 | 10:00 PM
brownc00's Avatar
brownc00
OK, so I went out and yanked the belt off (what fun!) and the waterpump is silky smooth and doesn't make noise or feel crunchy at all. The shaft will move a micro-fraction if you want on it as hard as possible.
The power steering pump shaft can be moved some. Not a lot. It feels smooth when it is spun, but I can get it to make a similar noise if I turn the pulley back and forth an inch or two. Think clockwise then anti-clockwise in a quick fashion over and over.
Old Mar 3, 2010 | 10:03 PM
Harsh20's Avatar
Harsh20
yeah the bearing in the water pump is designed to let you know it is going bad which is normally a high pitched squeal. also it will spit water from the weep hole on top of the pump.
but it could just be the tensioner itself making the noise. is the tensioner in spec? check the three little marks on top of the tensioner and see if it is still in range under tension.
Old Mar 3, 2010 | 10:33 PM
brownc00's Avatar
brownc00
Hey! You might be onto something there! I recently put a TPIS air pump eliminator on there and I noticed that since then, the tensioner is not as tight as it was. I don't think I needed the shorter belt for my year, but I wonder if that could be the problem.
Old Mar 4, 2010 | 06:36 AM
samsonb's Avatar
samsonb
You've also got a weep hole on the bottom of the water pump.
Old Mar 4, 2010 | 08:39 AM
WW7's Avatar
WW7
One way I have found to locate any noise is to get a long screw driver or pry bar and while the motor is running, put the handle to your ear and move from one part to another, putting the metel end against that part and listening , you can hear very clearly if that part is making the noise or not..this sort of works the same as a stetascope..Good luck...WW
Old Mar 4, 2010 | 07:19 PM
ex-x-fire's Avatar
ex-x-fire
Good advice WW7, here's a trick that I do too. I got one of those angle diegrinders w/ a roloc disk on it, take it & spin up each belt driven component. You'll know which one is making noise.
Old Mar 5, 2010 | 04:44 PM
joesgulfstream's Avatar
joesgulfstream
Old Aug 20, 2020 | 07:09 PM
Kimberley Etheridge's Avatar
Kimberley Etheridge
1st Gear
From key largo, florida
thank you bous6...
I too noticed that horrible loud sound and I saw water spitting out... thank you for sharing. Just got me a 1991 convertible 6spd. Quasar blue L98. Was 44,800miles now 49,400miles. Keep posting tips for us c4 newbees..
Old Aug 20, 2020 | 07:16 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
welcome to the forum, but, you just responded to a 10 1/2 year old thread.
Old Aug 21, 2020 | 09:19 AM
playsdixie's Avatar
playsdixie
welcome to the forum.....lot of good advice here......you'll need an fsm for the waterpump......it's not the funnest job on a c4.......
Old Aug 21, 2020 | 10:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed, as most of that damn air-tube chit on the front of the engine needs come off.
Welcome to the Forum and enjoy your '91; these 6-speeds are a blast to drive.
To Waterpump noise?
