Non Start...VATS?
Old Apr 22, 2010 | 02:35 PM
C4Mark58's Avatar
C4Mark58
Me too. I'm gonna give them a call, see if they can re-test it...Gave 'em a call, they said I originally had a blown resistor when I sent it in, everything else was OK. He said there is probably something in my ignition system that may be popping that resistor, great!
Old May 16, 2010 | 10:44 AM
C4Mark58's Avatar
C4Mark58
sent the ccm back for retesting, the tech was very helpful and assured me the unit is ok. Now what?
Old May 16, 2010 | 02:31 PM
C4Mark58's Avatar
C4Mark58
Small victory, The fuel pump is kicking on when I turn the key on but still no crank.???
Old Jun 6, 2010 | 11:35 AM
Millah's Avatar
Millah
clean your ground wire/connection to your block
Old Jul 23, 2010 | 08:40 PM
C4Mark58's Avatar
C4Mark58
[/IMG]
OK, here I go again. I don't get to work on this very often so it is taking forever. I've traced every ground and found none at fault. The ECM has been returned for testing twice and I've been assured it is OK. Relays, ign. switch, keys, neutral switch have been replaced. If I ground the black and yellow wire (indicated with arrow) it will start but then die after two or three seconds. It's driving me nutso!!
Old Jul 23, 2010 | 08:52 PM
C4Mark58's Avatar
C4Mark58
[IMG][/IMG]
