porting my Super Ram pics
Old Mar 8, 2010 | 11:10 PM
355tpipickup's Avatar
355tpipickup
[QUOTE=Caboboy;1573355197] My SR flowed 280 after some porting & gasket matching
How much porting did you do to it? was it more then mine? I would love to get mine to flow 280+cfm! Have any pics of the port work!
Old Mar 8, 2010 | 11:19 PM
cv67's Avatar
cv67
St. Jude Donor '05
Probably done with more carbide than flap wheel, thats how you really get some material out.
Old Mar 9, 2010 | 01:14 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Nice,,,is that w or w/o the base?
I've seen 289cfm for just the (ehoned) runners.
Old Mar 9, 2010 | 02:06 AM
Caboboy's Avatar
Caboboy
More gasket matching than porting....not nearly as much as you've done. I bench fit that sucker over & over to get things to come together consistently My heads flow 292 @ .600, but my cam only lifts to .565 if I recall correctly, so I was happy enough w 280 CFM from the intake.....the parts matched up pretty well
It's with the base, thru the TB
Here's some pics from my archives:
Old Mar 9, 2010 | 02:58 AM
NXS's Avatar
NXS
I think that before somebody just starts porting on these they should use a calculator like this to get some ideas:
http://www.wallaceracing.com/intake-runner-length.php
you just might find that siamesed runners removing some of the length with not only pickup flow but also cover dips in a power curve or bolster topend, or low end etc...
you might find that you are restricted in the maximum diameter and need a LONGER or SHORTER runner (easy to shorten to hit another harmonic)....
hope my brief post makes sense, if not contemplate on it...
Old Mar 9, 2010 | 09:10 PM
355tpipickup
[/QUOTE]
Oh wow, U didnt do much porting at all from the looks of it. What was done to the Base? If that ran 280cfm then after i port match mine and get thing liked up better i dont see how i can run the same or more! How much is it to have one flowed just to make sure im up in the 280+range?
Old Mar 9, 2010 | 09:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
It all depends how and where you port it to get the cfm. Just "hogging" things out can do more harm than good sometimes. Without really knowing what a motor will want its like going into it blind.
Old Mar 9, 2010 | 10:23 PM
Caboboy's Avatar
Caboboy
Ron's exactly right. As he mentioned earlier, you look good where you're at. The only recommendation I would have & Ron can correct me if I'm wrong, is to make darn sure to minimize the mismatch when you put it together in the final assembly. If your runner is even slightly off the base, you'll create a "shoulder" that'll play havoc with a smooth flow. I've always believed a true gasket match is just as important as a port job........maybe even more so. Especially with a superram and all it's darn mating surfaces.
I don't know what current costs are, my motor was done several years ago. I'd check out some machine/race shops in your area. I think you might be looking at 285 ish on your setup if it's gasket matched well.
Old Mar 9, 2010 | 11:54 PM
John A. Marker's Avatar
John A. Marker
As I recall, Caboboy has a 406 CI or larger engine that dyno'd at more the 550 HP. As you can see from his pictures, he has gasket matched the holes in the plenum without any porting. The SR does flow well without much work....the original design was from Lingenfelter.
Old Mar 10, 2010 | 12:27 AM
355tpipickup
Alright i took some close up pics with a camera. All i really did to the inside of the runners was use a 40grit flapper wheel and smoothed them out good. Then i took the wall out a bit and opened it up to swallow the golf ball. Also tapered the edge of the plenum to runner area. I will be goin back to bolt the runners to the plenum and make the plenum to runner match up so there is no "shoulders" at all! Also guess i should try and make the dividers less "knife" egded...i might have to take the divider back another 1/4" or so to get the rounded tho.
Old Mar 11, 2010 | 09:40 PM
355tpipickup
Alright tonight i port matched the plenum to the runners and also dropped the center wall some...tried to get rid of the knife edge also! Now ill be goin back and workin on the "pinch" points and then ill have to work on the base!
