low oil pressure
Old Mar 10, 2010 | 03:36 PM
lexman52's Avatar
lexman52
Default low oil pressure
Now on to my next problem, When car warms up at idle oil reads zero LBS. When driving it goes to about 35lbs. When i first start the car it is at 40 at idle then the warmer it gets {the engine} the lower the oil pressure drops. When water temp. is 200 thats when i have no pressure. What should i start to check. Steve
Old Mar 10, 2010 | 03:41 PM
Steve20's Avatar
Steve20
I would suggest hooking up a hand held oil pressure gauge to see if the one in car one is accurate.
What does the engine sound like when oil pressure > 0
Steve
Old Mar 10, 2010 | 03:58 PM
lexman52's Avatar
lexman52
Steve
Sounds fine. Haven't done that yet because it looks like a b
to get to.
Old Mar 10, 2010 | 04:02 PM
ittlfly's Avatar
ittlfly
Kind of sounds like your sending unit is going out.....that would be the easy fix.
Old Mar 10, 2010 | 04:04 PM
lexman52's Avatar
lexman52
Originally Posted by ittlfly
kind of sounds like your sending unit is going out.....that would be the easy fix.
where is sending unit located
Old Mar 10, 2010 | 04:48 PM
Mark85Vett's Avatar
Mark85Vett
what year?
Old Mar 10, 2010 | 06:14 PM
lexman52's Avatar
lexman52
Originally Posted by mark85vett
what year?
1986
Old Mar 10, 2010 | 06:25 PM
azrocketman's Avatar
azrocketman
Originally Posted by lexman52
1986
It's behind/under the distributor on the driver's (left) side. It is a pain in the butt to get to. Depending on your agility, removal of the distributor cap and/or windshield wiper motor is required. It's one of the first repairs I did on my '86.
What weight oil are you running? It sounds to me like the engine oil pump is not pressurizing the oil adequately as it thins out from temperature. How many miles on the car?
If you are high mileage and running 5W30 I might try 10W30 or even 10W40 and see if that makes a difference.
Steve
Old Mar 10, 2010 | 06:30 PM
lexman52's Avatar
lexman52
Steve
124k i just picked up this in feb. not sure what weight oil.
I thought it would be in a stupid place. Maybe i'll try it tomorrow.
Thanks, Steve
Old Mar 10, 2010 | 06:39 PM
azrocketman
Steve,
Their is a picure of the sending assembly in one of my original posts (New owner, Aug 2009) and some additional advice.
Good luck.
Steve
To low oil pressure
