LT1 Fuel Rail Question
Old Mar 10, 2010 | 05:43 PM
KBRVETTE93's Avatar
KBRVETTE93
Default LT1 Fuel Rail Question
Are the stock LT1 fuel rails adequate to handle increased volume of approx. 500hp crank hp? 42# injectors 58mm BBK AFR street elim. 195, cam.
Old Mar 11, 2010 | 06:46 AM
DVNCI's Avatar
DVNCI
According to this they say 350 max:
http://www.gmhightechperformance.com...use/index.html
But there are many high horsepower cars running stock rails. My car is fairly mild by today's standards, 420 or so crank HP and it's definitely fine.
No way to really know without testing I suppose - if you start seeing one entire side consistently run leaner than the other that might tell you you are starting to max it out.
Old Mar 12, 2010 | 12:44 PM
KBRVETTE93's Avatar
KBRVETTE93
What do you guys run (to upgrade the fuel rails) to supply higher hp combinations?
Old Mar 13, 2010 | 09:11 AM
DVNCI's Avatar
DVNCI
I would say the first thing you would do is eliminate the crossover tube and run the rails in parallel instead of series - eventually i will do this. If you search around here you will find a post or two where folks have done it on higher horsepower cars. Not that hard to do really, just need to modify the rails a little and put a dual feed pressure regulator on it (if you look on the Aeromotive website you'll see they have several types.)
To LT1 Fuel Rail Question
