Chrome front shocks?
Old Mar 11, 2010 | 10:10 AM
snoopdan's Avatar
snoopdan
Default Chrome front shocks?
Anybody know where I can purchase some chrome front shocks?
Old Mar 11, 2010 | 11:56 AM
snoopdan's Avatar
snoopdan
Bump, surely someone at some time had to of bought some for their ride.
Old Mar 11, 2010 | 12:56 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
No idea. Chrome and performance are usually two separate categories.
You might try posting this in off topic rather than tech/performance
Old Mar 11, 2010 | 01:00 PM
snoopdan's Avatar
snoopdan
Not true, everyone knows chrome makes your car faster
Old Mar 11, 2010 | 01:36 PM
redrose's Avatar
redrose
i have steel chrome 'carrera' shocks, heim ends top/bottom, inverted, on the front my 86...small mod needed to upper mount to use the heim vs oem stud...had a bunch of slightly 'abused' stuff on the shelf,left from circle trick racers, decided to try for giggles, 'turn-in' is so good it's almost shocking (sorry abt pun)...gonna put the matching rears on before spring roll-out (hopeful)...carrera is now owned by qa1 AFAIK
Old Mar 11, 2010 | 01:47 PM
snoopdan's Avatar
snoopdan
Id actually like to see a picture of that mod! sounds cool!
Old Mar 11, 2010 | 02:03 PM
redrose's Avatar
redrose
chrome weighs less than paint...also lightens your wallet faster than paint if that matters...common for race stuff to be just 'california chrome' one dip with no copper/nickel prelim dips as corrosion prevent is not critical, saves weight.
Old Mar 11, 2010 | 02:12 PM
Kubs's Avatar
Kubs
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
To get a "chrome" look it has to be dipped in nickel first. Chrome is actually clear and just makes an otherwise dull nickel finish shine!
Old Mar 11, 2010 | 02:17 PM
StealthLT4's Avatar
StealthLT4
Umm, QA1 shocks are pretty close to chrome...
Old Mar 11, 2010 | 02:18 PM
snoopdan's Avatar
snoopdan
I don't care how you do it as long as I get some chrome shocks on my ride
Old Mar 11, 2010 | 02:29 PM
redrose's Avatar
redrose
our racer bumpers/etc were shiny steel that got just a single dip at a local bumper rechrome shop, looks good and 'wears' better than paint...another local plating shop nearby does 'hard chrome' on hydraulic cylinder rods for wear resist, will not even do other plating dip, shines great...'low buck' custom auto chrome wheels rust/peel in short, several plating pros have said those are 'calif chrome'...could 'shiny steel' underwear suffice ?
Old Mar 11, 2010 | 02:33 PM
snoopdan's Avatar
snoopdan
these here?
Old Mar 11, 2010 | 02:52 PM
redrose's Avatar
redrose
gotta make the oem round hole square and drill 2 holes 5/16''.
Old Mar 11, 2010 | 02:59 PM
redrose's Avatar
redrose
http://www.speedwaymotors.com/Carrer...hocks,179.html
mine are p/n 255 3254 IIRC (p/n hides when mounted)
Old Mar 11, 2010 | 03:52 PM
LBYRNES's Avatar
LBYRNES
I just put the QA1 shocks on my '93 yesterday. They are chrome and go on with no modifications.
I haven't driven on them yet because I'm waiting for some bushings for the rear sway bar.
Old Mar 11, 2010 | 04:19 PM
snoopdan's Avatar
snoopdan
thanks for all the great replies!
Old Mar 11, 2010 | 05:10 PM
StealthLT4's Avatar
StealthLT4
Yup, those QA1's are the ones. Very nice shocks too. More of a machined aluminum finish (which I like more than chrome personally...), but very nice.
Old Mar 11, 2010 | 11:09 PM
JrRifleCoach
Your killin' me!
You can save the same amount of weight by throwing out the ashtray.
Of course there's the ol' saying, "If it don't go, chrome it".
Old Mar 12, 2010 | 07:20 AM
mseven's Avatar
mseven
qa-1's are alum. with a clear coat, if doing coil overs the spring is p.coated silver.
To Chrome front shocks?
