'86 strange sound
Old Mar 11, 2010 | 11:29 PM
drewplunkett's Avatar
drewplunkett
Default '86 strange sound
I have a strange sound from my 86. At about 3000rpms there is a "air sound" coming from what I think is my throttle body. The sound is like when you open a high pressure air fitting from a compressor. its a pretty loud "woosh." It is most notable when you open the throttle and allow the revs to go to at least 3000rpms and then close the throttle. I thought it might be a pulley bearing but I am pretty sure that the sound is coming from within the throttle body. Maybe its the egr pumping exhaust back into the intake? I just dont know I am at a loss.
Old Mar 12, 2010 | 11:17 AM
Paul Ruggeri's Avatar
0Paul Ruggeri
Former Vendor
You can eliminate the pulley question by removing the belt and trying it.
If the noise is still there, get a mechanic's stethoscope and se if you can pin down the sound.
Old Mar 12, 2010 | 08:20 PM
383vett's Avatar
383vett
On high mileage c4s the throttle body shaft can wear and can cause noise like you are experiencing.
Old Mar 12, 2010 | 10:21 PM
drewplunkett
took belt off, the sound is coming from the throttle body.
. is there a repair for this or do i have to replace the whole TB.?
Old Mar 13, 2010 | 04:01 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Originally Posted by drewplunkett
took belt off, the sound is coming from the throttle body. . is there a repair for this or do i have to replace the whole TB.?
To '86 strange sound
