Cold Air Intake
Old Mar 12, 2010 | 09:25 AM
GACC's Avatar
GACC
Default Cold Air Intake
My air box is all beat up, I need to repair to look good. Thinking of adding a cold air intake from after market. Any one have advice. This for a stock 87 C4
Old Mar 12, 2010 | 09:50 AM
Aardwolf's Avatar
Aardwolf
Don't expect large gains with one. Most are more for looks. I wouldn't get one that has many filters to clean, it's to tedious!
Old Mar 12, 2010 | 09:54 AM
GACC's Avatar
GACC
Don't really want gain looks is good. Thanks
Old Mar 12, 2010 | 09:55 AM
ks5shooter's Avatar
ks5shooter
St. Jude Donor '10-'11-'12-'13
Here ya go
http://www.lmperformance.com/1751/25.html
Old Mar 12, 2010 | 09:57 AM
GACC's Avatar
GACC
Originally Posted by ks5shooter
That will work, haven't found these guys before. Thanks
Old Mar 12, 2010 | 10:17 AM
tequilaboy's Avatar
tequilaboy
If I was still N/A, I'd pick up a cheap used C5/C6 air bridge, run a tube through a hole in the shroud and mount the filter underneath exposed to the cold air. Watch out for deep water, though.
Or something like this:
http://www.aacorvette.com/performanc...roducts_id=292
They have 2 versions (new and old???)
It may take some experimentation to get it to fit, but should be easy enough.
This approach also offers a relatively easy upgrade path to a larger diameter MAF, which would eliminate the two primary intake airflow bottleknecks (the stock airbox neck, and maf itself).
I have (and used to use) the SLP kit linked above. It adds a nice intake howl, but doesn't do too much to improve looks or performance.
Old Mar 12, 2010 | 11:30 AM
Redvette_22's Avatar
Redvette_22
Look into the "Air Force One" that TPIS sells, or the Breathless Vortex unit.
Old Mar 12, 2010 | 11:36 AM
GlennS87's Avatar
GlennS87
I didn't see the AirForce 1 on the TPIS website. Do they still offer it?
Old Mar 12, 2010 | 01:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Look into the "Air Force One" that TPIS sells, ...
I run the SLP ram/cold air package but think Vic'89 got better results with the Air Force I.
Though TPIS shows installation instructions for Air Force III they do not list it on-line??? Might be worth an email to them.
Old Mar 12, 2010 | 07:01 PM
warship's Avatar
warship
wow I used to live down the street from AA corvette. they are a great buch of guys. I spent a good amount of time just talking to them at the shop.
To Cold Air Intake
