87 Loose steering column
Old Mar 12, 2010 | 09:53 AM
GACC's Avatar
GACC
Default 87 Loose steering column
Anyone have advice on 87 C4 tilt wheel that is loose. All works but from years of pulling on it has become wiggly
Old Mar 12, 2010 | 11:23 AM
T. Wayne Nelson's Avatar
T. Wayne Nelson
My 85 was the same way, after looking at all of the options I contacted a guy on the forum, he sold me a used one for $50, took about 3 hours to replace, tight as a drum. Make sure they send the keys if you are going to use the key lock that is in the column.
Old Mar 12, 2010 | 01:04 PM
01spirit's Avatar
01spirit
Cruising
I had the same issue with my 85. I found a local guy who works on steering columns. I removed it and took it too him. He took mine apart and tightened up the internal screws and used loctite. I do not recall what I paid him thou.
Chris
Old Mar 12, 2010 | 05:45 PM
joeld's Avatar
joeld
Just disregard the 1st section on the air bag removal.
Joel
http://domesticmisfits.net/forums/vi...ring+clumn+fix
Old Mar 12, 2010 | 06:06 PM
PBnf's Avatar
PBnf
Joel
Joel:
This is probably the best set of instructions I've seen on this site. That's quite an accomplishment. Thank you.
Old Mar 13, 2010 | 09:55 AM
GACC's Avatar
GACC
Very impressive, doesn't seem to tough. Thanks Much
To 87 Loose steering column
