current favorite spark plugs on a c4
Old Mar 12, 2010 | 09:24 PM
pologreen1's Avatar
pologreen1
Default current favorite spark plugs on a c4
I have exhaust of for the LT's and I am going to do plugs right away.
Anything better out there lately, or any that seem to work well in an L98?
(heat wise ETC)
Oh any heat shields for the wires?
Old Mar 12, 2010 | 09:53 PM
Weav's Vet's Avatar
Weav's Vet
(heat wise ETC)
I''ll give you a deal on some red shields if you decide you need them. Never been used.
The Green Rocket's Avatar
The Green Rocket
Unless you have a power adder or changed to a different style of cylinder heads - the stock spark plug in the brand of your choice is what you should use.
Adding the exhaust from an LT1/4 will not affect your spark plug heat range.
Thomas
Old Mar 13, 2010 | 08:18 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
L98 - AC/Delco replacement for stock
Old Mar 13, 2010 | 08:22 PM
pologreen1's Avatar
pologreen1
Thomas
I just meant the brand. I have it off, for the headers and I have duals. I will probably stay with stock brand, I have never run anything else in vettes before, but I would try some thing new if others had good experiences.
Old Mar 13, 2010 | 08:25 PM
dogfish246's Avatar
dogfish246
Read this!!!
Its good stuff!
http://www.streetmachineclub.com/upl...ugs-lowres.pdf
http://www.streetmachineclub.com/upl..._PLUG-DATA.pdf
Old Mar 13, 2010 | 08:28 PM
pologreen1's Avatar
pologreen1
I'll do that right now, thanks.
Old Mar 13, 2010 | 08:35 PM
dogfish246's Avatar
dogfish246
What do you think? This read was passed on to me a week or two ago from a fellow forum member and I really like it!
If you can find some of those mystery plugs then you will be ahead of the game!!!
FYI, the test was done on a Corvette LT1 (C4) motor so... Gives us pretty good numbers!
Old Mar 13, 2010 | 09:01 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
NGK TR55 or Autolite 606 in my LT1.
Old Mar 13, 2010 | 09:32 PM
pologreen1's Avatar
pologreen1
dogfish246 the mystery plug, sounds neat.
Old Mar 13, 2010 | 09:48 PM
427c4vette's Avatar
427c4vette
That mystery plug sure looks a lot like the surface gap plugs out of a 1973 65 hp Mercury outboard that I used to own.
Old Mar 13, 2010 | 09:54 PM
samsonb's Avatar
samsonb
I'd just stick to a stock type plug. I don't think I'd trust Bosch anyways after all the bad things I've heard of their plugs in a GM engine. Plus that Bosch +4 they make is complete BS.
Old Mar 13, 2010 | 10:14 PM
GTA8500's Avatar
GTA8500
Originally Posted by joshwilson3
i'd just stick to a stock type plug. I don't think i'd trust bosch anyways after all the bad things i've heard of their plugs in a gm engine. Plus that bosch +4 they make is complete bs.
very right!! I had the bosh +4 on my camaro and the thing was running rough i had to replace them with stock acdelco plugs. Since then i only use stock plugs!
Old Mar 13, 2010 | 10:41 PM
l98tpi's Avatar
l98tpi
Max G’s
I've ran NGK's in my autox car for 5 years, pulled a couple out to inspect recently and still look great. Run A/C Delco stock plugs in my stock car and seem to be fine. For plug wires, I run A/C Delco 8mm wires on both cars, no issues.
Old Mar 14, 2010 | 03:50 PM
j-wireman's Avatar
j-wireman
I have that magazine. Some surprising numbers, there.
I'd say get the AC/Delco Rapid Fire plugs. I just don't think spending $17.60 extra for 0.6 HP is worth it ($2.20 x 8 = $17.60) versus the AC/Delco Professional.
Just my two cents.
Old Mar 14, 2010 | 09:23 PM
Strick's Avatar
Strick
For what it's worth, I put NGK TR55IX Iridium plugs in mine about 5 years ago. They still look new. Even the gap stayed the same. Now I must be honest, I only put about 20K on them even with 2 years of auto crossing.
Old Mar 14, 2010 | 10:11 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
How the hell can you guys read that small print.
To current favorite spark plugs on a c4
Old Mar 14, 2010 | 10:18 PM
The Green Rocket
Kimmer, after you pull up the link if you look towards the top you will see a menu tool bar - look for where it has % and note that there is a "+" and a "-". Select the "+" until you get to 100% or whatever makes it readable for you.
Thomas
Old Mar 14, 2010 | 11:38 PM
samsonb's Avatar
samsonb
I wouldn't get the regular AC Delco plugs. I had some installed, and a month later. I noticed all the plugs bases had rusted. The OEM's were made of metal that wouldn't rust, just like the current Rapid Fire plugs. I'm guessing those regular AC Delco plugs are made by Autolite, as they both have that dark metal that will rust.
I replaced them with the copper NGK plugs which won't rust.
Old Mar 15, 2010 | 12:15 AM
sick-punk's Avatar
sick-punk
Mystery plug resembles the plugs that come in a rx7 rotary engine, only difference is the rx7s has a crosshatch in it. alright i found them they're also made by a company Torque master, "problem claim is that the large center electrode has broken in a few engines ruining the cylinder and piston" i think a spark is a spak fuel/compression is the main worry when it comes to powerband.
