removing lt1 water pump drive?
Old Mar 13, 2010 | 04:04 PM
sthamby's Avatar
sthamby
Default removing lt1 water pump drive?
Does anyone know if there is a way to pull the water pump drive out of an lt1 block without using the Kent Moore tool? Is there a more common puller that can be used or another way to get it out. Thanks.
Old Mar 13, 2010 | 04:31 PM
STL94LT1's Avatar
STL94LT1
The water pump drive is lightly pressed in. If you have the intake off, tap it forward. If not, lock a pair of Vice-Grips on the shaft and tap it forward.
Old Mar 13, 2010 | 04:57 PM
Strick's Avatar
Strick
When I removed mine, I went to the Chevy dealer and made a deal. I bought the tool to remove it and then returned it for a refund. Trick is, they kinda knew me as I go there all the time.
Old Mar 13, 2010 | 06:03 PM
sthamby's Avatar
sthamby
I don't have the intake off so I'll try the vise grips. Thanks.
To removing lt1 water pump drive?
