88 Replacement Dash Bulb Replacement #'s
Old Mar 13, 2010 | 07:18 PM
Da Mail Man's Avatar
Da Mail Man
Default 88 Replacement Dash Bulb Replacement #'s
Greetings All,
.....It's been a while!...Have a burned out bulb in my 88 dash cluster...I thought somewhere that there was an inexpensive replacement/drop-in bulb someone had come across as a replacement for same......
......Anyone have that number handy and is it the SAME brightness as the original?......THANKS!
Old Mar 14, 2010 | 01:03 AM
jfb's Avatar
jfb
Nope, no low cost replacement. 882 is the lamp number. I have read here that later C4's used a different lamp that is xenon instead of quartz halogen and is cheaper and the same pins but is too long to allow the silver reflectors to seat. I recommend installing the bulb that it was designed for.
Old Mar 14, 2010 | 06:06 AM
Da Mail Man
......thanks for the reply.....ok, i thought that someone had located a replacement some time ago...maybe i will attempt search for thread and see what gives.....thanks....
Old Mar 14, 2010 | 12:26 PM
Da Mail Man
.......ge?....sylvania?......
Old Mar 14, 2010 | 01:20 PM
pmihaltian's Avatar
pmihaltian
Slingshot
GE 882 is the OEM bulb and you can get them at NAPA and I'm sure most all of the auto part stores.
My suggestion is that when you get the dash panel out and disassembled, replace all four bulbs while you are at it. I replaced a single burned out bulb once and less than a month later another one went out. They are a little expensive, but the new bulbs have a pretty long life so you won't have to do it again for quite a while.
Old Mar 22, 2010 | 09:27 PM
jimgiggles's Avatar
jimgiggles
There is a cheaper alternative, Joe C posted a few times about these bulbs here.. http://www.lightbulbsdirect.com/page...XXenon/X5G412V
Link to original thread: http://forums.corvetteforum.com/c4-g...nel-bulbs.html
Also found these on ebay.. http://cgi.ebay.com/ebaymotors/84-89...Q5fAccessories
To 88 Replacement Dash Bulb Replacement #'s
