Help - Whats this Superram Setup worth?
Old Mar 13, 2010 | 07:19 PM
RayHampton's Avatar
RayHampton
Cruising
Default Help - Whats this Superram Setup worth?
Guys,
Looking for your input and opinions on what this Superram setup would be worth if I decided to sell it. It is complete and includes,
  • Superram Plenum
  • Superram Plenum Runners
  • DFI Superram Manifold
  • Throttle Body 58mm
  • IAC
  • MAF
  • TPS
  • Cold Air Intake and Air Cleaner
  • Fuel Rails
  • Fuel Injectors 32lb
  • Fuel Pressure Regulator
  • Fuel Filter
  • Fuel Pump High Volume
  • Acell DFI Standalone ECU
  • Wiring Harness
The Accel DFI is an older model, works great just not the latest DFI. Exotic Muscle can provide a harness that will connect this ECU so that the standard gauge cluster works. This setup is in excellent condition and doesn't have that many miles on it. Its off my back-up engine. Your opinions on what you think this is all worth would be appreciated. A complete setup without the DFI, pump, filter, sensors and cold air intake is about $5K online.
Thanks.
Old Mar 14, 2010 | 01:08 AM
355tpipickup's Avatar
355tpipickup
what brand injectors are they? how much you lookin for them alone? Also have any pics to post of this SR setup?
Old Mar 14, 2010 | 03:13 AM
pologreen1's Avatar
pologreen1
I have seen similar set ups go for 2500 on ebay
To Help - Whats this Superram Setup worth?
