Why 86 odd ball
Old Mar 13, 2010 | 10:15 PM
Marv02's Avatar
Marv02
Default Why 86 odd ball
I trying to find out when I look up motor parts and other parts for my 86 Vett why it seems most parts say 1985 and earlier or 1987 and latter I don't get it.
What make the 86 a odd ball and which parts should I be looking at for motor parts for my eary 1986 L98 with Iron heads.
I want to rebuild the motor in soon but what parts should I get and can I use center bolt type heads on my 1986 L98 vett Motor.
Old Mar 13, 2010 | 10:38 PM
JackDidley's Avatar
JackDidley
86 was a change over year. Early 86, iron heads. Late 86 alluminum heads. 86 also got a one piece rear main seal. You can use center bolt heads. Make sure they have the correct bolt pattern for your intake. Its just the old style standard SBC intake bolt pattern.
Old Mar 13, 2010 | 10:44 PM
l98tpi's Avatar
l98tpi
Max G’s
And I thought you didn't know jack didley
Old Mar 13, 2010 | 10:45 PM
Marv02's Avatar
Marv02
Default thanks this helps
Thanks that clears some issues up for me I think at least for now.
Old Mar 13, 2010 | 10:51 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
The 86 and up L98 was a one piece rear seal for the block.The 85 and earlier engines have a 2 piece seal.
The 86-91 L98 Vette engines,you can reuse the stock intake manifold...it bolts right up....the L98 that came in other cars,like the camaro and firebirds,the intake manifold middle bolt holes are a little different in the 87 and up F cars.
In 1987 and later,all L98s had a roller lifters cam set up.The 86 and earlier engine has a hydraulic one.
With your 86 engine block,yes,you can use just about any good centerbolt heads should you choose to.You will need to make sure the compression and cc is ideal for your use,along with the cam you choose.
Old Mar 13, 2010 | 11:12 PM
Marv02's Avatar
Marv02
Thanks everyone for sheding some light on whats going on I have a better idea what I looking at now.
Old Mar 13, 2010 | 11:21 PM
Marv02's Avatar
Marv02
I just need a better understanding about the head and intake manifold I planning to change out the intake manifold anyways have to find out which one I need for centerbolt heads.
I planning to put next step hotter cam set Comp Cam Dur 256/268 Lift 447/454 Rpm range 1000 to 5200d Edelbrock heads ans intake.
I mite make it a 383 stroker.
This is a CA and I still have get by smog check.
Old Mar 14, 2010 | 12:02 AM
ch@0s's Avatar
ch@0s
L86 had aluminum heads like the 87.. take your oil cap off and look inside if the # end is 113 you have a L86 aluminum head and roller cam.
Old Mar 14, 2010 | 12:33 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
85 engines got lower fuel pressure and 24 LB injectors, forged pistons, 2 bolt block.
The only differences early 1986 engines had that was different from 85 and earlier was the one piece seal, right hand dipstick and newer oil pan and pan rails. There was a switch to cast pistons, they still had 2 bolt mains, and the 76cc iron heads with revised valve seals, and nylon cam gear.
late 86 got roller cam block with 2 bolt mains, roller cam, centerbolt aluminum heads with 58cc chambers, dished pistons, iron timing chain, guided rockers, right hand dipstick, one piece seal, and newer style harmonic balancer.
in late 88 they switched to 113 heads from the 128 heads, dropped the cold start injector in 89.
They continued this till 90 when they reprogrammed the computer chip, used the MAP sensor, used flat top pistons with revised timing and the 58cc heads.
Old Mar 14, 2010 | 12:59 AM
Aggravated4life
Your 86 engine/heads uses the traditional SBC intake manifold bolt set up.
If you buy heads meant for a Corvette,say 86L-87 aluminum,or simply the 88-91 Vette aluminum D port heads,they all use the same sbc intake bolt pattern.The F cars,the Camaro and Firebird,87 and up L98,has a different intake bolt set up in the heads and intake manifold.
That said,alot of aftermarket intakes are pre drilled to bolt on to BOTH Either the 87 and up camaro/firebird L98 or the 85 and up Vette L98.
Old Mar 14, 2010 | 01:02 AM
Aggravated4life
Thats wrong.
There is no L86,its an L98.
The late L98 '86-87 aluminum heads,the 128 style,are not the same as the 113 heads that came out in 88-91.Very similar,but not the same design.Same intake bolt pattern though.
Old Mar 14, 2010 | 01:06 AM
Aggravated4life
Theres a minor mistake there...The late 86 engine with aluminum 128 heads did not Have a roller lifter cam.That came out in 87.
The L86 still used a hydraulic cam.87 was the first year they installed the roller lifters.
Old Mar 14, 2010 | 01:44 AM
ch@0s's Avatar
ch@0s
Originally Posted by Aggravated4life
Thats wrong.
I meant late 86 .. mine had 113 heads but I didn't buy it new.
Old Mar 14, 2010 | 01:40 PM
JAKE's Avatar
JAKE
Also, my early iron headed 86 Vette had a four bolt block, one piece rear main seal and a flat tappet hydraulic cam.
When I re-built it - came out a 355 - I installed Edelbrock Performer RPM aluminum heads and the intake fit without any issue.
Jake
Old Mar 14, 2010 | 03:00 PM
Marv02's Avatar
Marv02
Default Will heads alone help.
Did you use the stock intake if so did the heads alone improved the over rev the motor just neds to pull a little longer untill red line mine starts falling on it face about 4500 RPM's.
I don't want a high reving motor just some more over rev.
Jake
To Why 86 odd ball
