LT1 TIMING COVER SEALs
Old Mar 17, 2010 | 01:06 PM
sthamby's Avatar
sthamby
Default LT1 TIMING COVER SEALs
I just purchased a new timing cover for '93 lt1 with the seals already installed. All 3 seals had black grease applied to them. I had heard before that the water pump drive and opti seal needed to be installed dry. Is this the case? Will the grease cause a leak? Don't know if I should clean it off or not. Thanks.
Old Mar 17, 2010 | 02:40 PM
desertmike1's Avatar
desertmike1
The grease is applied to extend the shelf life of the chevron seals, you can wipe this off, and Apply a light film of engine oil on both surface's before assembly.
Old Mar 17, 2010 | 03:10 PM
sthamby's Avatar
sthamby
Thanks!
To LT1 TIMING COVER SEALs
