On a 415 L98 one tube of TPiS non-coated long-tubes developed a pin hole leak at the top of #5 right where it turns to go down coming out of the head. T
That effected idle and was immediately noticeable. Couldn't be heard, but the idle quality went south noticeably. JUST a pin-hole, too!Headers had less than 10,000 miles on them.
In my experience, it's the equal, gradual tightening of bolts that lead to a good seal with no leak. Same principle as when torquing head bolts, intake manifold bolts, etc.,; tighten them all in sequence and gradually to apply equal clamping.
Tightening in other methods can often warp the sealing surfaces. So, no, I wouldn't just tighten the center bolts more. I'd go over all of them and work from the center out to the ends a little at a time.
Make sure the headers aren't being held or restricted by the rest of the exhaust system. You don't want to be trying to tighten them in place while the rest of the exhaust is applying an opposite force - essentially fighting against your efforts. It would be best for the headers to be completely disconnected from the remainder of the exhaust system; everything down-stream. Then, once the headers are tightened in place, the rest of the exhaust system bolted to them.
Best results would probably be attained using high quality, new gaskets too. Fresh surfaces all around. Pay close attention to the amount of torque being applied - No gorilla tightening. 30 ft lbs is all it should take, especially since you're probably torquing into aluminum.
