adfpr
Old Mar 11, 2002 | 06:03 PM
devilfish's Avatar
devilfish
Default adfpr
I have the plenum off and going to put in a adfpr. How do I meassure the fuel pressure I have now? Must i start the car? Or is it just to unplug the vaccume lines to the fpr to get maximum preasure?
Old Mar 11, 2002 | 11:32 PM
No Ordinary 91's Avatar
No Ordinary 91
Cruise-In III Veteran
Default Re: adfpr (devilfish)
remove and plug the vacum line to the AFPR and then set the pressure using the adjusting nut.
Old Mar 11, 2002 | 11:36 PM
dtorc4's Avatar
dtorc4
You need to get a fuel pressure gauge and hook it up to the nipple on the passenger side fuel rail - it will have a screw off cap. Once you do this, attach the guage to the nipple, unplug the vacuum line to the FPR, and measure your pressure at idle and WOT. I don't remember what your readings should be, I'm sure somebody else will chime in on it.
To adfpr
