Unbelievably Filthy Brake Fluid...
The old pads were pretty well used up, the rotors looked better than I though they would; a quick trip to the brake lathe to get the old dust off and get rid of the glazed areas and the rotors were good as new (I'm glad I didn't have to buy new rotors - money is getting tight). I checked the run-out, that was within specs for all four rotors. A hour and a can of WD-40 was devoted to the emergency brake cables - links were tighten; grease and oil were placed to the appropriate areas.
My pressure-bleeder had a broken neck to the part that fit on the master cylinder so the Mighty Vac was used to bleed the lines. I was replacing the brake lines with braided lines from the car to the brake cylinders but didn't want brake fluid on my garage floor.
I was shocked to see what I removed from the brake lines/master cylinder:
No, it's not used motor oil or really strong coffee - it's ancient brake fluid - the very worst I've ever seen.
Needless to say, my brake system now has clean Valvoline Synthetic brake fluid.
My '79 Vette has squealing brakes and I'm planning to replace the pads within the next month. I really fear what its brake fluid looks like.
So gang, a quick question: Can 15 years of neglect cause the fluid to become this dirty (and a lot thicker than the new brake fluid)? I know brake fluid is hydrophillic and loves to absorb moisture when it can, so can that be a contributing reason for the old fluid to be dark? Have the brakes been severely overheated to cause this?
Any information will be greatly appreciated.
sewage water.
When I got my vette in 1997, my fluid looked just like that, and my brakes seemed to work ok, although the pads and such needed upgraded, it was a functioning system.
I flushed it all out, and cleaned the resovoirs, they were black too,
and its been clear as ice ever since, feels good every time I look at it, not to mention use them, ha.
And the bone heads have chunky BLACK brake fluid!!!!
Makes me crazy
If you feel up to it, take off one of the front calipers, and take it apart,
remove the boot, and look at the cylinder and all.
Maybe those need rebuilt too, or cleaned at least.
An easy job really. I did all 4 of mine, after I saw my fluid was black sludge. My pistons cleaned up nice, and with a boot, rings,
all in the rebuild kit, its all fresh again.
Just be sure if you cant get the piston out, and use an air hose
point that thing away from your body, ha, it could shoot out like a shotgun slug, no lie.
I'll stop by Checkers or Advanced Auto later today to get another two bottles of brake fluid and will be prepared for what to expect from the '79.
Usually the abs and asr go crazy and pulsate the brakes when you step on them ,when the fluid gets like that every 2 years.I just suck it out and put in new just did that last week,another chevy defect ,like the chevette and vega.OH! forgot about the controled seapage the engine always has.
I feel the same way when I see that pretty clean fluid in the reservoirs - Schwing !
I had an 88 where the old brake fluid was really thick. Looked like chocolate pudding and had almost the same consistency.Now for the bad news, well it was my experience - remeber I spend time on the road course with mine.
I flushed mine with ATE blue when I bought it. After every event I had to bleed, and flushed every other event. Switched to ATE gold after a year, same thing, Last year I switched to less expensive and more available Valvoline synpower, same bleed flush schedule.
I was ALWAYS getting grey fluid out! So this winter I replaced the master, booster and all 4 calipers. NO MORE always grey fluid. Before I had to pump 6 - 8 times to get clear fluid at a wheel. Now it is 1-2 which is perfect! Only had 2 events, but so far I'm very happy.
brake fluid will attract up to 5% water every year from what I've read.
Some people say it can gain water through plastic bottles and they only use fluid out of a sealed metal can.
My neighbor never did anything to her 95 Olds 98. Last week they put a new master cylinder on it. The trash and water mixed with the fluid and corroded the bottom of the bore and ate up the seals.
The big deal people forget about is the ABS. It has some tight tolerance solenoids. When trash hangs them up it's big buck to fix.
JS
JS
2 times a year on the racecars, bleed the calipers every race, fluid in the caipers gets a very light gold color in one race.
