skip shift
Old Mar 19, 2010 | 10:43 PM
womblesd's Avatar
womblesd
Default skip shift
Can someone tell me how to unhook the skipshift, and where to find the electrical connection involved? That feature is a pain.
Thanks in advance
Old Mar 19, 2010 | 10:54 PM
Harsh20's Avatar
Harsh20
crawl under the vette and look at the driver's side of the transmission there you will find a electrical connector (grey)just unplug it. you can buy a eliminator plug to protect the connectors or just wrap them to keep oil out of the plugs
Old Mar 19, 2010 | 10:55 PM
STL94LT1's Avatar
STL94LT1
It's on the left side/middle of the transmission.
Old Mar 19, 2010 | 10:57 PM
Mrs. glass car's Avatar
Mrs. glass car
The worst thing GM ever did. How anyone can drive the car with that thing connected is beyond me. It is the 1st thing I did when I got the car home from the dealership. It has been 14 years but if I remember, just raise the car on the drivers side and next to the trans on the drivers side you will find a wire connector. Separate the wire connector that makes the connection that will disable the solenoid that locks the shift linkage forcing 1 to 4 shifts. The dash will still indicate 1to4 but you can shift normally. Several after market corvette parts suppliers make a cover for both ends of the connector along with a cable tie so you can close off any opening on the connector halves and tie the wires up out of the way.
Old Mar 19, 2010 | 11:00 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Here is a post with some pictures.
http://forums.corvetteforum.com/1571882016-post8.html
Old Mar 20, 2010 | 01:43 PM
womblesd's Avatar
womblesd
Thank you very much for everybody's comments. I have ordered the part.
Dan Wombles
St Louis, MO
Old Mar 20, 2010 | 02:39 PM
NMsharkracer's Avatar
NMsharkracer
From: Formerly from the Great White North but now residing in the Desert Southwest NM (The Land of Dis-Enchantment?)
[QUOTE=glass car;1573480590]The worst thing GM ever did.QUOTE]
But it did keep the Vette from the Gas Guzzler Tax. I'm glad they made it easy to defeat.
To skip shift
