Seat nut torque specs?
Old Mar 20, 2010 | 05:19 AM
Phantom_Vette1's Avatar
Phantom_Vette1
Default Seat nut torque specs?
Hi just a quick question!
can someone please inform me of the seat (track to floor) nut torque specs?
also the (track to seat) bolt specs!
on a 90 c4
Old Mar 20, 2010 | 09:33 AM
Bill32's Avatar
Bill32
20 ft lb on both.
Old Mar 20, 2010 | 10:59 AM
WW7's Avatar
WW7
Do people really torque seat bolts?? Really?? I just put them in and tighten them down....WW
Old Mar 20, 2010 | 11:26 AM
c4cruiser's Avatar
c4cruiser
The factory nuts are jam nuts so trying to torque them would not give a proper reading. You don't want to go too tight as jam nuts will easily strip the threads on the studs.
Old Mar 20, 2010 | 11:30 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Old Mar 20, 2010 | 12:31 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
you can't properly torque lock nuts that are used, so just tighten them with a standard length 3/8 ratchet, and don't get them too tight.
Old Mar 20, 2010 | 01:01 PM
floridamale's Avatar
floridamale
Old Mar 20, 2010 | 01:20 PM
383vett's Avatar
383vett
Seat bolts should be torqued when the car is in the sun and the motor warm. Do it after checking the horn bracket mounting bolts.
Old Mar 22, 2010 | 11:17 AM
Phantom_Vette1
well i don't know, i just thought that they should be done up correctly, i mean i want them to be safe!
Anyway i read that other seats are around 18ft lb so i will do that!
Old Mar 22, 2010 | 03:52 PM
383vett's Avatar
383vett
Better safe than sorry. Good luck! Don't mind our corny replies.
Old Mar 22, 2010 | 05:31 PM
WW7's Avatar
WW7
If your in an accident thats bad enough that your seats come out I don't think it will matter what you torqued them at, but I can't knock someone for doing something the right way....WW
To Seat nut torque specs?
