Is something fishy between these two bobweights?
Rod Weight: 434g
Rod Weight: 434g
Bearing: 49g
Bearing: 49g
Oil: 4g
Piston & Pin: 584g
Locks: 4g
Rings: 51g
Rod Reciprocating: 180g
BobWeight = 1789
Since our Piston/Pin weights were significantly different, I'm wondering how our bobweights could end up so close?
Is there a mistake on one of our build cards? (Or worse, in one of our balance jobs?)
1) how can the pin weigh 1 gram? and the rings 56?
This might help you...It indicates that Eagle "target balances" their cranks.
http://www.enginebuildermag.com/Arti...balancing.aspx
Best I can figure, Dane's rods must be SUPER light or there was a mistake. My pistons are ~80g's lighter but my rods must be that much heavier than his.
His are written as 560g whereas mine are split into "big end/little end" weights of 434g and 180g. If the total of those two weights is the total rod weight, mine are way heavier! Mine are 4340 Scats.
(FWIW: I was comparing my card to a couple of recent builds just to see how the Wiseco's compared, and how my RA compared in weight. Comparing to Sliding's thread, my rings must be darn heavy -- or they're not really 51g for 2 sets.)
