water leak
Old Mar 20, 2010 | 07:05 PM
art2239's Avatar
art2239
Default water leak
Took my ruby vert on its first top down ride in what seems like years. Long story short on the way home I started to smell anti freeze[ never a good sign] then the low coolant light, temp never got above 220 and I made it home. Anti freeze is pissing out from the rear of the passenger head cant quite see exactly were from I can see the metal tube that connects the two heads and is fed by a half inch water hose Is this a common leak source or should I assume its the head gasket
