85' Engine Swap
Old Mar 20, 2010 | 08:01 PM
L98Pickup's Avatar
L98Pickup
Cruising
Default 85' Engine Swap
Hey Guys, new to the forum and the vette scene. This project is my first time dealing with a Corvette or even doing a swap all together. I purchased a 1985 L98. Brought it home today alone with a 1986 computer (couldn't find a after market harness for the 85) Have a tone of questions. Hope to get a little help. First two right off the bat, Can you remove the a/c unit and run the engine without it? or do you just not hook it up? Also wanted to know what the hoses are going into the exhaust manifold and if you have to run then with headers? Any info on either subject would be great... Even very basic info, I'm a newbie to the whole mechanics of vehicles... thanks
Old Mar 20, 2010 | 08:16 PM
rodj's Avatar
rodj
What you neeed to do to run '86 computer on '85
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
How to
http://forums.corvetteforum.com/1566807620-post48.html
Air injection, if you do the A/c delete as shown above you delete the air pump and all the plumbing as well
Old Mar 20, 2010 | 08:34 PM
L98Pickup's Avatar
L98Pickup
Cruising
Thanks for the reply alone with the links. The second one about the a/c unit removal just seemed to be a picture....
Old Mar 20, 2010 | 09:05 PM
rodj's Avatar
rodj
A pic is worth a 1000 words
You swap the Corvette water pump for a std rotation one and run a shorter belt .Part #'s for swap included in link.
As SHOWN in pics, anything to do with A/c is deleted and th e Alt becomes the belt tension adjustment point like on a old style setup
http://forums.corvetteforum.com/c4-t...te-pulley.html
Old Mar 20, 2010 | 09:38 PM
L98Pickup's Avatar
L98Pickup
Cruising
Would I be alright running a AIR eliminator kit?
http://cgi.ebay.com/ebaymotors/TPI-L...item3efdbf85d6
Old Mar 20, 2010 | 09:56 PM
L98Pickup's Avatar
L98Pickup
Cruising
Also was told if you run a kit like this one that you eliminate the risk of damage to your alternator because you keep the bracket that attaches to the front?
Old Mar 20, 2010 | 09:58 PM
rodj's Avatar
rodj
If you are going to trouble of deleting the A/c you may as well put $$ from now unneeded air pump eliminator towards new water pump
Old Mar 20, 2010 | 09:59 PM
rodj's Avatar
rodj
Front of what?
Old Mar 20, 2010 | 10:02 PM
L98Pickup's Avatar
L98Pickup
Cruising
guess a kit like that does nothing to eliminate the a/c unit though.... (thinking out load and reading posts on link)
Old Mar 20, 2010 | 10:12 PM
rodj's Avatar
rodj
All that does is delete the AIR pump and replace it with a pulley so you can keep stock belt
A/c compressor is on other side of engine
Old Mar 20, 2010 | 10:29 PM
L98Pickup's Avatar
L98Pickup
Cruising
By the sounds of it the 1982 rotation pump and adjustment rod is the way to go. Says you need the short Block to hub measurement style pump... Have any clue what that size is? Or how to tell when you go to purchase one?
Old Mar 20, 2010 | 10:48 PM
rodj's Avatar
rodj
In the parts list linked above ;
70's to '82 Corvette waterpump
Old Mar 20, 2010 | 10:57 PM
L98Pickup's Avatar
L98Pickup
Cruising
http://cgi.ebay.com/ebaymotors/SBC-C...item58848a32e9
Old Mar 20, 2010 | 11:28 PM
L98Pickup's Avatar
L98Pickup
Cruising
Just one more question, the standard rotation water pump i'm guess turns the opposite direction then the late 80's pumps? And what the advantage? Thanks again
To 85' Engine Swap
