94 6 Speed - Replace Shifter Boot
Old Mar 20, 2010 | 09:17 PM
pjinca's Avatar
pjinca
Default 94 6 Speed - Replace Shifter Boot
I have a 94 6-Speed and the lower shifter boot is cracked (the rubber one under the leather one). I found a replacement online and before buying, I am trying to find out how easy it is to pull and replace.
I have the console trim off, do I just take out the 4 nuts and pull out or do I need to remove the whole console to get at? The rubber just looks like it is tucked under the console, so I am hoping it is as easy as taking out the nuts, pull out the boot, put in new one and tuck it in, and reassemble in reverse.
I am hoping to get a confirmation that it is just that easy.
Thanks in advance,
Patrick
Old Mar 20, 2010 | 10:24 PM
Jagdpanzer's Avatar
Jagdpanzer
This old thread should help you out
Scroll down to post #18
http://forums.corvetteforum.com/c4-z...r-install.html
Old Mar 21, 2010 | 04:22 AM
pjinca's Avatar
pjinca
Thanks - looks like it should just pop right out out. I will order the replacement today.
To 94 6 Speed - Replace Shifter Boot
