Sensor Question
Old Mar 21, 2010 | 11:39 PM
umfan's Avatar
umfan
Default Sensor Question
I have a 1989 L98. What sensor is located on the driver side of the engine block, between the front 2 spark plugs. I think it is a coolant sensor. The connector is broken at the pigtail and on the sensor. Does anybody have part numbers? Thanks.
Old Mar 22, 2010 | 12:23 AM
86PACER's Avatar
86PACER
Fan switch that controls the secondary (auxillary) fan on dual fan cars.
Old Mar 22, 2010 | 01:09 AM
samsonb's Avatar
samsonb
When does that fan turn on? Only if there is an over heating situation?
Old Mar 22, 2010 | 01:13 AM
86PACER's Avatar
86PACER
The stock aux fan switch closes at above 228 degrees, which kicks the aux fan on.
Old Mar 22, 2010 | 01:15 AM
samsonb's Avatar
samsonb
I've had my 89 idle to where the main fan turns on. But I've never seen the second fan turn on. So I figured it turned on at a higher temp.
Old Mar 22, 2010 | 04:29 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Both Corvette American & MAM offer that connector in a package with a lower temp aux fan switch at around $35-$40; maybe Vette2Vette (Vette bone yeard) has just the connector & cable to the fan relay.
Old Mar 22, 2010 | 05:29 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Auxiliary Fan Sensor about $13 at most Corvette parts houses. http://www.ecklers.com/search.asp?ac...searchHistory=
Old Mar 22, 2010 | 07:32 PM
samsonb's Avatar
samsonb
It looks like they have it for $25. Though, I do wonder how much the fan will be running if it turns on at 200 degrees and turns off at 185 degrees:
www.mamotorworks.com/corvette?frame=1.944
. Auto System Kicks Fan(s) On At 200 Degrees And Off At 185
. Replaces Existing Auxiliary Fan Switch
. Handy Conversion Harness Simplifies Wiring Connection
Low Temperature Electric Cooling Fan Switch helps maintain optimum performance operating range while keeping your Corvette's engine cool. Conversion Harness is required for all 1990-91 Corvettes and 1985-89 Corvettes with single fan. A new harness is recommended on all, but is an optional replacement for cars with auxiliary fan. Instructions included.
Old Mar 22, 2010 | 10:13 PM
umfan's Avatar
umfan
Thanks for all the help guys!
Old Mar 23, 2010 | 08:04 AM
94vettelover2's Avatar
94vettelover2
I thought only 90-96 vettes had 2 cooling fans
Old Mar 23, 2010 | 12:16 PM
samsonb's Avatar
samsonb
On my 89, I have the main fan. Then there is a fan in front of the condenser. I've never seen this fan turn on.
Old Mar 23, 2010 | 08:18 PM
impact1968's Avatar
impact1968
I've wired both my fans (aux and main) to turn on and off at the same time.
Old Mar 23, 2010 | 11:25 PM
86PACER's Avatar
86PACER
Early cars had the option of dual fans.
Old Mar 24, 2010 | 02:48 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Yes, early C4s had available option B4P - Radiator cooling boost fan @ $75.
Old Mar 24, 2010 | 02:50 PM
pmihaltian's Avatar
pmihaltian
Slingshot
The front auxiliary cooling fan only comes one if your engine temp exceeds 235 degrees. Its a good thing if this does not happen often.
Old Mar 24, 2010 | 03:11 PM
samsonb's Avatar
samsonb
Yeah, that is what I was thinking. It is a backup fan if the car overheats. It doesn't normally come on.
Old Mar 24, 2010 | 03:24 PM
redrose's Avatar
redrose
only time mine ever came on was when the green wire played on the manifold and the insulation melted...thought for a second that something expensive died from the noise level, shut engine down and noise seemed even louder...wtf
now have a manual over ride switch tied in, have yet to need it.
To Sensor Question
Old Mar 24, 2010 | 04:35 PM
94vettelover2
I didn't know that
Old Mar 28, 2010 | 07:36 PM
chileverde's Avatar
chileverde
Newbie here with a fan switch sensor issue - I want to lower the cooling fan cycle on my 1994 LT-1 to 210deg. on / 195deg. off. Which leads to my next question:
Is the 1994 LT-1 main radiator fan being controlled by the engine computer reading a variable resistance temp sensor, or by a thermostatic on/off switch unit like what it sounds like is being described for the 1989 C4?
If it's a switch, I'm going sensor shopping for a lower temp switch. If its ecu controlled, then I'm gonna have to get more creative...
Rob
Old Mar 30, 2010 | 10:56 AM
chileverde's Avatar
chileverde
anyone? anyone? bueller? bueller?
Guess I figured it out on my own... The fans receive instructions not from a fan switch type sensor, but by the pcm after reading a temp value from a variable resistance sending unit.
Damn... guess I'm going to have to add an aftermarket thermostatic control to one of the fan relays and series it in with the existing relay wires from the pcm.
Rob
