Brake Light Issue Please Help
Old Mar 23, 2010 | 02:20 PM
C4 Dutch's Avatar
C4 Dutch
Default Brake Light Issue Please Help
Ok 92 Coupe
Apply the Brakes and only 3rd break light works checked fuses and all good ...any sugestions? Thanks in advance for your help
Old Mar 23, 2010 | 02:41 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
I'm sure you have a bad fuse. On my 92 the brake fuse was blown.
Old Mar 23, 2010 | 03:27 PM
C4 Dutch's Avatar
C4 Dutch
I am pretty Sure I checked the Fuses. Do you KNow what fuse it was in your Car?
Old Mar 23, 2010 | 07:44 PM
JackDidley's Avatar
JackDidley
When my 87 does that, it is the brake light switch at the pedal. Its a double switch that power the third brake light seperately. Easy fix. Maybe $12.
Old Mar 24, 2010 | 06:19 AM
Flame Red's Avatar
Flame Red
+1 - mine was the opposite, the third brake light did not work but the tail lights did.
Old Mar 24, 2010 | 07:05 AM
C4 Dutch's Avatar
C4 Dutch
Thank you all for your Help I'll give it a try!
Old Mar 24, 2010 | 08:56 AM
jaa1992's Avatar
jaa1992
St. Jude Donor '12
On my 92, looking at the fuse panel on the passenger side it is the lower left fuse, hard to see it but it is labeled "Brake". my lettering was worn off.
If its the switch and you decide to change it yourself - your a better man than I, after the cussing and swearing that went on changing the booster its going to the shop if I need to change any of that stuff under there.
To Brake Light Issue Please Help
