Guess that part!
Old Mar 25, 2010 | 09:05 AM
garychurchill's Avatar
garychurchill
Default Guess that part!
Ugh. So last night my buddy was helping me pull out the driver's side (95 LT1) manifold for getting headers in. In a fit of gorilla-man rage he pulled up too hard and low and behold broke the end off right of this guy. Its located above the oil pan and kinda on the side of the engine. I don't think it's for coolant, as nothing leaked out as I slowly removed it just in case.
I've been looking this morning, thinking it's an oil pressure sensor or something, but haven't found any pictures to back it up.
Old Mar 25, 2010 | 09:13 AM
garychurchill
I think it's the oil temp sensor?
Old Mar 25, 2010 | 10:21 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
If you have an aux fan, it could be the switch for that. On L98's it's between 1 & 3 cylinders.
Old Mar 25, 2010 | 10:35 AM
garychurchill
This is in the back near the oil filter. Above the oil pan. I'm 99% sure its the Oil Temp sensor. Just another pain in the assssss
Old Mar 25, 2010 | 12:12 PM
surfer92's Avatar
surfer92
You can see the grime from the coolant.
Old Mar 25, 2010 | 12:20 PM
garychurchill
wouldn't coolant leak out if it's pulled? there's not a drop of coolant.
Old Mar 25, 2010 | 07:38 PM
aboatguy's Avatar
aboatguy
If its mounted on the head it is the sensor assembly coolant guage (name from 6A1B-4 FSM)
and I broke one back in 2005 installing my headers the first time..
Coolant came out of my head when I pulled it to remove a new one (not much because I was expecting it and was quick ...if yours is dry you may have a low coolant level or your cooling system has some crusties...plugging the hole..
Old Mar 25, 2010 | 08:43 PM
MarkBychowski's Avatar
MarkBychowski
If it was towards the rear of the driver's side block above the oil filter, it's the oil temp sensor. There should have been a little oil on it, though (unless that's why you were pulling the motor )
There are two coolant temp sensors on LT1/LT4 vettes: one in the passenger-side head, one in the front of the water pump.
The knock sensor is in the middle of the side of the block as well, but it doesn't look like that.
Old Mar 25, 2010 | 09:07 PM
Al Borman's Avatar
Al Borman
Sir, I believe that you are 100% correct, that is your oil temp. sensor.
That's a pricey little sucker....around $35 at rock auto.
Old Mar 26, 2010 | 09:08 AM
garychurchill
Mark & Al, I am positive that is what it is too. I snapped this photo earlier
Old Mar 26, 2010 | 06:33 PM
pmihaltian's Avatar
pmihaltian
Slingshot
click to enlarge photo
To Guess that part!
