How much do U-Joints Cost
Old Mar 12, 2002 | 06:34 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default How much do U-Joints Cost
How Much and from where?
Will
PS
I am gonna do the work myself!
Old Mar 12, 2002 | 07:02 PM
ittlfly's Avatar
ittlfly
Default Re: How much do U-Joints Cost (flyinace2000)
Hey Will.
Like we said before, it's not a bad job and take your time. I got mine from a NAPA dlr and bought Spicer u-joints. Get the ones with the grease fitting on the end caps and not in the trunion. (the +) this allows for easier access to the fittings. you will be able to grease them as normal maintance as you will not want to do this job again for a while.
Old Mar 12, 2002 | 07:58 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: How much do U-Joints Cost (ittlfly)
Toms differentials sells a really good set of U joints as well. They work really well if you have lots of mods. Lots of good results on here with them for high HP cars.
Old Mar 12, 2002 | 08:09 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Got Spicers from NAPA, think they were either $120 or $150 for all six.
Old Mar 12, 2002 | 08:11 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: How much do U-Joints Cost (Mr Mojo)
I'm using the same ones. There seam to be real strong.
Old Mar 12, 2002 | 08:15 PM
pablocruise's Avatar
pablocruise
Spicer u-joints. Get the ones with the grease fitting on the end caps and not in the trunion. (the +) .
Is this a weak point at all in the joint itself? I think I saw some joints with no grease fittings in them at all. :confused: Anyone have the link to Tom's Diff?
I too am looking for joints that can take lots of power+slicks.
Mr Mojo's Avatar
Mr Mojo
Default Re: How much do U-Joints Cost (mackeyred96)
There you go, two drag racers using the same parts. Between the two of us, over 500 passes on these and still holding up.
Old Mar 12, 2002 | 09:08 PM
BobMachus's Avatar
BobMachus
Yup, Spicers are the way to go. Listen to the masters.
[Modified by BobMachus, 6:08 PM 3/12/2002]
Old Mar 12, 2002 | 09:31 PM
Bluevette85's Avatar
Bluevette85
Brute Force 12.99 each at Autozone. No grease fitting but I doubt you need them for daily driving. Racing is another matter.
Old Mar 12, 2002 | 09:54 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: How much do U-Joints Cost (Bluevette85)
Stay away from Brute Force, whether you race or not, you don't want inferior products, just ask Vette92 about Brute Force, he has pics somewhere.
Old Mar 13, 2002 | 01:54 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Brute Force versus Spicer.
I would not recoomend Brute Force for anything other than a door stop or paper weight.
When they go, they take the half shaft with them so it is more costly than just a new u-joint.
[Modified by Vette92, 11:59 AM 3/13/2002]
Old Mar 13, 2002 | 02:37 PM
Mr Mojo's Avatar
Mr Mojo
Default Re: How much do U-Joints Cost (Vette92)
:yesnod:
Old Mar 13, 2002 | 03:32 PM
GlockLT4's Avatar
GlockLT4
eek!! I think u-joints is going to be my next project... that as well as doing bushings.
Old Mar 13, 2002 | 04:32 PM
Goody's Avatar
Goody
Default Re: How much do U-Joints Cost (Glock'94)
Bought mine at NAPA as well. Pretty cheap and not too difficult. Hope you have a large vice to work with and the proper ujoint puller. I broke a 6" c clamp trying to get them out and bent an 8". Get a real clamp for doing this type of work to save some headache. :seeya
Old Mar 13, 2002 | 04:36 PM
GlockLT4's Avatar
GlockLT4
Default Re: How much do U-Joints Cost (Goody)
Is there a how to guide for changing them? I haven't ever done it. I do have a very large shop clamp though :D
Old Mar 13, 2002 | 04:40 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
I bought the biggest vice that Home Depot carried. Using two socket, one larger inside diameter than the outside diameter of the u-joint cap, and one the same outside diameter. Place one on each side of the installed u-joint and compress. Pull the one cap off when it is fully compressed and slide a socket on where the cap was, use one with a smaller OD than the original cap. Put the larger socket on the other end, compress. This will get the u-joint off. Getting them back on is easier, but you use a similar process.
Hope that made sense.
Old Mar 13, 2002 | 04:57 PM
scorp508's Avatar
scorp508
You have to be kidding me, you're way too active of a user to of missed this. :)
http://personal.tmlp.com/scorp/vette...nts/index.html
To How much do U-Joints Cost
Old Mar 13, 2002 | 05:25 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: How much do U-Joints Cost (scorp508)
I forgot Scorp had such a nice writeup on the procedure.
Old Mar 14, 2002 | 04:26 PM
Jim-K's Avatar
Jim-K
My NAPA wants $35.00 each for them. :eek: Anyone know where to get them cheaper?
Jim-K
Old Mar 14, 2002 | 06:12 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Default Re: How much do U-Joints Cost (Jim-K)
http://www.tomsdifferentials.com
