QA1 Shock Mounting Problem
Old Mar 12, 2002 | 08:05 PM
427 Predator's Avatar
0427 Predator
Supporting Tuner
Default QA1 Shock Mounting Problem
I just bought front and rear HAL QA1 shocks for my '94 LT1. Rears go on fine but there is a problem with the fronts. The holes in my front shock towers are 0.875" diameter but the nipple on the poly bushing included with the QA1 shocks is only 0.610" outside diameter - so I have over 1/4" slop if I use their poly bushings. Can't use the poly bushings that I used on my Bilsteins because the Bilstein shaft is larger diameter than the QA1 shaft, so this would just be shifting the problem from the shock tower hole to the bushing hole, which would eventually wallow out the bushing.
QA1 says they have never heard of this so either I have a very strange Vette or they haven't sold many of their shocks for C4's. I AutoX my Vette and either have to get a fix for the problem or send the shocks back.
Anybody experienced this and/or have a solution?
Thanks :confused:
Old Mar 12, 2002 | 08:10 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: QA1 Shock Mounting Problem (gsgreenwood)
Welcome to the forum and WHAT were your shocks designed for??????
I think mine were for an '81 camaro but not sure.
Old Mar 13, 2002 | 11:55 AM
0427 Predator
Supporting Tuner
Default Re: QA1 Shock Mounting Problem (mackeyred96)
John, thanks for the welcome.
I assumed the C4 shocks were designed for it but from what you are indicating this is apparently not the case. Did you experience any problem similar to mine when you installed your front shocks?
Also, please let me know whether or not you like these shocks while I still have the opportunity to send them back.
Thanks for your help. :cheers:
To QA1 Shock Mounting Problem
