adjusting valve lash?
Old Mar 12, 2002 | 09:26 PM
Detroit Vette's Avatar
Detroit Vette
Default adjusting valve lash?
i went through the correct procedure. followed the order at top dead center. rotated 360. and then did the rest. i tightened them until i felt alittle resistance while spining the push rod, and then went an extra 3/4 of a turn to set the preload.
what confuses me is when i turned the crank 360 to finish the other rockers. the ones i had just finished were so loose i could rotate the rocker right off the push rod???????? what is going on here????? :crazy:
Old Mar 12, 2002 | 09:40 PM
VMAX451's Avatar
VMAX451
Default Re: adjusting valve lash? (sdixon)
When you rotated the engine, the lifters on bled down when encountering resistance while raising the pushrods. This is normal. Assuming your initial adjustment was correct, nothing to worry about and no need to redo them.
Old Mar 12, 2002 | 10:23 PM
Detroit Vette
Default Re: adjusting valve lash? (Vince Ivanc)
so as soon as the motor buils oil pressure they will pump back up?
Old Mar 12, 2002 | 10:43 PM
VMAX451's Avatar
VMAX451
Yup. Now the question is, when you originally found zero lash before pre-loading, were they collapsed at all then ? There's a light spring in the lifters to hold them fully "extended" even if they're fully bled down, but if you aren't careful you might unknowingly compress it. A lot of people do the adjustment with the engine running to avoid these issues, but that has it's drawbacks (like hot oil slinging all over the place).
Old Mar 12, 2002 | 11:11 PM
Bluevette85's Avatar
Bluevette85
I noticed this looseness when I adjusted my valves, so I readjusted them. Car wouldn't start because I tightened them too much and the valves were open all the time. Had to loosen and start all over again. Moral: adjust correctly once and all will be well.
Old Mar 12, 2002 | 11:18 PM
Detroit Vette
Default Re: adjusting valve lash? (Bluevette85)
ya i did the same thing, readjusted them. so i will need to start over. after they have "bled down", how do i readjust them? should i loosen them all back up, and wait for the lifters to open back up?
Old Mar 13, 2002 | 12:27 AM
92corvette's Avatar
92corvette
If you have just put in 'new' lifters, you may have to re-adjust them after you get it started up and the lifters pump up. I found that I could NOT get them right until then.
[Modified by 92corvette, 10:28 PM 3/12/2002]
Old Mar 13, 2002 | 01:03 AM
Bluevette85
I emailed you the procedure that another forum member sent me. It worked well.
Old Mar 13, 2002 | 10:34 AM
Torre's Avatar
Torre
I must be loosing it!!
I did not know you could adjust valve lash with hydraulic lifters.
Somebody please inform me!
Old Mar 13, 2002 | 11:10 AM
Red5's Avatar
Red5
Bluevette85.
Please forward those directions to supervetteracer@cs.com.
Thanks,
Old Mar 13, 2002 | 07:52 PM
JAKE's Avatar
JAKE
I just sent you a email of the procedure I's used for years and the one I send to guys who have the same problem as you.
Let me know if I can help further.
Jake
Old Mar 13, 2002 | 10:57 PM
Bluevette85
Default Re: adjusting valve lash? (JAKE)
JAKE is the man! He sent me the procedure and it worked great and I have been passing it along to others.
JAKE, you should post it in Tech Tips! :)
Old Mar 14, 2002 | 01:32 AM
C4-Wolf's Avatar
C4-Wolf
If it doesn't get posted in tech can you send me a copy to wandzekjm@hotmail.com
Jeff
Old Mar 14, 2002 | 01:41 AM
Bluevette85
Default Re: adjusting valve lash? (C4-Wolf)
92vette and C4-Wolf you have mail.
Old Mar 14, 2002 | 01:01 PM
C4-Wolf's Avatar
C4-Wolf
Thanks Bluevette, those instructions will be very helpful
To adjusting valve lash?
