Should I....
Old Mar 12, 2002 | 11:39 PM
flyinace2000's Avatar
flyinace2000
St. Jude Contributor
Default Should I....
While replacing my U-Joints should i do anything else? Since i will have some of that stuff disassembled
Will
Old Mar 12, 2002 | 11:44 PM
vader86's Avatar
vader86
Default Re: Should I.... (flyinace2000)
check the wheel bearings
Old Mar 12, 2002 | 11:46 PM
flyinace2000
Default Re: Should I.... (vader86)
Both replaced with the last 6 months!
Will
Old Mar 12, 2002 | 11:49 PM
devilfish's Avatar
devilfish
se if you have some oil leaks from the output shaft of the tranny. feel if the c-beam bolts are tight enough. gut your cat ;)
regards
Old Mar 12, 2002 | 11:50 PM
vader86's Avatar
vader86
well then just check for oil and tranny leaks like he said
Old Mar 13, 2002 | 12:02 AM
scorp508's Avatar
scorp508
Clean! :) Makes it easier to spot leaks in the future.
Old Mar 13, 2002 | 12:58 AM
GlockLT4's Avatar
GlockLT4
Default Re: Should I.... (scorp508)
Yup, i agree with scorp.. do as much cleaning as you can when you tear something apart. You'll be glad when it comes time to find the next problem .. or simply when you show your car :).
To Should I....
