1990 intake options? need help
This may be just what you are looking for; not the ultimate weekend warrior fighter, but a damn fine street fighter that is silly fun http://www.firstfuelinjection.com/products.htm not the low price leader, but if you do a search this one comes up as being worth the difference. Keep in mind that their product comes very complete with throttle body etc. - it is a good value for what is there.
Thomas
For an interim solution (especially if you don't feel confortable doing mods/porting/etc...), that FIRST intake isn't the worst option you could consider. The main obstacles there are the fuel lines and possibly the distributor.
The SR is really the other "crossover" intake that competes in both the torque and HP categories. IOW, keeps good torque for lower powered motors, but winds up higher than your current intake.
The USR HSR and/or the mini could/should be considered as well.
To be honest, ANY of these intake options are going to run you north of $1000 by the time you install them. Used options might save you a couple hundred but the $500 "perfect" manifold doesn't pop up everyday.
To be honest, porting isn't that hard. I self-taught myself to do it with a drill, burr, flap wheels, and some patience. Learning how to port is worth your time and improves what you can do.
For a large tube intake (and lack of desire to port), the TPIS or AS&M tubes are hard to beat. At least they provide the best flow out of the box. But, I'm not sure I'd consider that unless you ONLY wanted to swap runners. A base + runners is $800. For that, you can find a super ram. Or, buy a FIRST, used mini, or whatever. That's because you're gettin' up into the $1000 range I was talkin' 'bout.
Plan on a grand, learn to port, or stop the leak and call it good.
