1986 Won't stay running. Code 34.
Old Mar 30, 2010 | 08:28 PM
sarcher's Avatar
sarcher
Default 1986 Won't stay running. Code 34.
CODE 34
Where do I begin? And is this a common code for the car not to start or stay running?
Old Mar 30, 2010 | 10:39 PM
jfb's Avatar
jfb
Code 34 sets when the ECM has seen low air flow, less than 2.5 gm/sec when engine is first started or above 600 rpm or TPS (throttle position sensor) above 6% (2300 rpm in neutral). One symptom is rough unstable idle. Unplug the MAF and if idle becomes more stable, then replace the MAF. MAF unplugged and engine running, the ECM should set a 33 and if after resetting codes and unplugging the MAF and 34 is reset, the MAF wiring or ECM is at fault. Check dirty or misadjusted throttle body. Also check air ducts for tightness and not cracked. Code 34 will set also if the idle speed is set too low.
Old Mar 30, 2010 | 10:46 PM
sarcher's Avatar
sarcher
Good to know. But my problem is, I can't get it to run for more than a second or two.
Old Mar 30, 2010 | 10:54 PM
jfb's Avatar
jfb
Unplug the MAF and see if it will start and run. Also, if the idle is set too low, the engine will start and immediately quit (hold a little throttle during starting). I also recommend watching the fuel pressure to see if it is between 35-42 psi and it holds up after the ignition is turned off and also if it holds up during starting. You might have leaky injectors (won't hold pressure, ign off) or a defective fuel pump (won't hold pressure during fuel delivery), or a fuel filter clogged (won't hold fuel pressure during fuel delivery).
Old Mar 31, 2010 | 03:50 PM
sarcher's Avatar
sarcher
MAF Burn off relay and Power relay>? Where do I find these? I have called every part store and no one has them, or even has a part listed. I came up with part number AR227SB for the Power but no matches online. I call local Chevy dealer and they say the same part for both relays>(?) I have called Ecklers and they are only showing the burn off relay no Power relay. Help. I figure if I'm taking apart the MAF I might as well replace the relays while I'm in there.
Old Mar 31, 2010 | 08:13 PM
jfb's Avatar
jfb
The mass burn off relay and the mass control relay are both on the firewall in the engine compartment on the left side and above the jump start terminal. There is no relay called, "power relay". Don't take the MAF apart! there isn't anything inside of it that is owner serviceable! I gave you some things to try, what are the results?
Old Mar 31, 2010 | 09:18 PM
boardroomjimmy's Avatar
boardroomjimmy
Power relay pn.# 10067925, burnoff relay pn.# 10094701, specific for m.y. '86. Bought from local chevy dealer last week. They had them in metro area, delivered in 2 hrs to dealer. (portland/vancouver) Went to dealer because napa was coming up with multiple other p.n.'s, a little more money, but their the correct ones. You can also buy online, google the p.n.'s. I'm beginning to wonder if my issues were a wet wiring harness. Car ran fine until I washed it, sat for 4 days, went to start it and threw 2 codes. Coincedence? maybe. Also ck your fuel pressure at the rail, start with the simple.
Old Mar 31, 2010 | 09:48 PM
sarcher's Avatar
sarcher
Default Power and Burn Sensor
Thanks. I just called the Local Chevy dealer and he couldn't get for a couple days. I got the product/part # from him and called O'Reilly. They will have them for me in the morning. Also I removed and cleaned out the MAF and started up and died like it always has. Thanks for the info.
Old Mar 31, 2010 | 09:53 PM
sarcher's Avatar
sarcher
I took off the MAF and spray cleaned it with MAF cleaner and tried to start the car with it unplugged. No changes. Just started then died. I am have a hell of a time locating the fuel filter. I guess I will replace the the relays tomorrow and try again to find the fuel filter. Is this something that can be reached without a lift? Hope so.
Old Mar 31, 2010 | 09:56 PM
sarcher's Avatar
sarcher
Default Fuel pressure
jfb
Is there a standard gauge or is there one made for this car? Do you recommend a fuel pressure gauge?
Old Mar 31, 2010 | 11:47 PM
boardroomjimmy
Pick up a fuel pressure test gague when yer at the auto parts store. Mine came with correct adapter already fitted, with a ford adapter in the pkg. Fuel filter is right behind the pass. front tire on the frame rail. You can get it with a jack and stands just fine. I'm betting on fuel delivery issue. I may go so far as to buy f.p. gague first and ck. b4 buying relays. New f.p. at napa was 150ish? very ez to change.
Old Apr 1, 2010 | 07:19 PM
jfb's Avatar
jfb
You can not go wrong buying tools or test equipment. Fuel pressure gauges are about $12 at parts houses and extremely valuable for trouble shooting. You can learn how to fix your own cars and it is MUCH less expensive than repair shops charge!!!! The MAF relays aren't very expensive and they don't last forever, so I don't see anything wrong in replacing them. You can test with a voltmeter to see if they are switching power to the MAF to prove that your relays are good or not. Another valuable thing to own is a VOM (voltmeter, ohmeter, milliammeter), so you can measure resistance, current, and voltage. You don't need an expensive one, you can buy a digital VOM from Harbor Freight for $8 and it is accurate. I own two of them. On sale, I have bought them for $1.99.
Old Apr 5, 2010 | 11:53 AM
sarcher's Avatar
sarcher
Default Still out of commission!
Changed out the relays. Started right up. Ran for about 5 minutes. Thought Great. Then I shut it off, started it back up, and what do you know, died after a sec or two. I checked fuel pressure, couldn't get a reading even while trying to start it. Who knows, Maybe didn't hook it up right, didn't look like there was a wrong way. Just frustrated. I attempted to change the fuel filter and couldn't get it to loosen at all. Taking a break.
Old Apr 5, 2010 | 12:53 PM
RRT vette's Avatar
RRT vette
Attach the fuel pressure gauge and turn the key to "on". You should get a reading on the gauge in the neighorhood of 34-40 psi. If you don't get a reading, you are likely not getting fuel.
Have you tried to remove the intake air duct and spray starting fluid in the throttle body while someone cranks the engine?
Did you reset the ECM and check for codes again?
Old Jul 11, 2012 | 03:52 PM
Jammer100's Avatar
Jammer100
1st Gear
on a 1986 corvette why would it run for a few minutes and the die. has a rough idle.already replaced the mafs and still have the same code 34 show.
Old Dec 23, 2024 | 11:38 AM
vibzzy's Avatar
vibzzy
1st Gear
Code 34 facing the same this guide help me. Take a look. Read here
Old Dec 24, 2024 | 04:10 AM
mikey999's Avatar
mikey999
Cruising
I had the same issue and code. I have an 89. I purchased a good new MAF unit off rock auto and replaced the 2 relays by the battery. Car only running for a few seconds is a sign the MAF is done. My Corvette had the original Delco unit so 35 years old. After replacing disconnect the battery for 30 minutes or so and that will re-set the codes the re-connect and start it up. My Corvette has run fine after I replaced these a few months ago.
To 1986 Won't stay running. Code 34.
